meshing
User: "VAL1"
Altair Community Member
Updated by VAL1
I want to remesh after setting up another parameter.
how should I do?
1 - 14 of 141
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi naoki,
    You can change the surface selector to elements in the automesh panel and select the element to re-mesh and click mesh.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.02ab6a3217a062a1bb4ba6ebba9292e6.png
    Thank you
    Altair Employee
    Hi,
    Is your issue resolved?
    Thank you
    User: "VAL1"
    OP
    Updated by VAL1
    Hi Premanand
    Thank you, but I want to mesh after create tetra mesh.(Solid mesh)
    Is it possible?
    Altair Employee
    Hi Premanand
    Is it possible?
    Sorry i didn't get you. You mean, you want to create tetra mesh after 2D mesh?
    Thank you
    User: "VAL1"
    OP
    Updated by VAL1
    I mean the model has already meshed 3D.
    I want to retry the 3D mesh fineness.
    Altair Employee
    Delete the mesh and re-do it.
    Thank you
    User: "VAL1"
    OP
    Updated by VAL1
    Thank you for early reply.
    How should I delete the mesh?
    Altair Employee
    Simply hide the geometry and delete the elements displayed.
    Thank you
    User: "VAL1"
    OP
    Updated by VAL1
    Thank you so much.
    I have another question.
    Now I try Non-linear transient analysis.
    I want to change animation intervals, where should I change?
    I changed  TSTEP⇒ N,DT, is it not enough?
    I don't know the meaning of  NLPARM⇒NINC , NLOUT⇒NINT, they are default value.
    Altair Employee
    Prakash Pagadala is expert in Non-linear. I think he replied to your question. Please ask him, if you have any doubts about this. He will be happy to help you, don't hesitate :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    Thank you
    Altair Employee
    @naoki
    NINC is the implicit load sub-increments. If your NINC is 10, the load will be divided into 10 and applied in 10 increments (provided pure convergence),
    NLOUT is used to output incremental results in h3d format. Start with default value and keep SVNONCV to YES
    User: "VAL1"
    OP
    Updated by VAL1
    Thank you , So in case I set 1.0s time duration in the tstep.
    and NOUT/NINT 10.
    the animation is divided 0.1s?
    User: "VAL1"
    OP
    Updated by VAL1
    I have one more question
    what is the relationship between TSTE/N,DT and NOUT/NINT ?
    TSTE/N is sampling number, DT is interval?
    Altair Employee
    Yes, Dt is the time increment and N is the time step value for DT
