can no longer copy paste subprocess with content (RM7.2)
Not sure whether this is new to 7.2 as I skipped a few versions, but if I want to copy a process that contains operaters (say a loop or subprocess) only the parent container is copied, but the internals are empty. Is this something by default ?
In the past everything inside an operator was also copied (so parent and childs) , but if only the parent is saved now this is kind of a step back.
I've migrated from 6.2 to 7.2 if that might help.
Thanks for your understanding - we already filed a request for a patch release and will keep you updated when this is ready...
Cheers,
Ingo
All,
We have just released RapidMiner Studio 7.2.1 with a couple of fixes, including this one. Please upgrade via the Marketplace and copy-pasting subprocesses should work again as expected. Thank you for your patience!
Best, Zoltan
What version of Java are you using, we recommend version 8.
