🎉Community Raffle - Win $25
Join and Win
ParameterTypeList bug
User: "Vaclav"
New Altair Community Member
Updated by Jocelyn
Hello,
I have problem with using ParameterTypeString in connection configuration. It does not load saved XML text properly.
I have created my own implementation of AbstractConfigurable and AbstractConfigurator<> which contains ParameterTypeList. When I paste XML text, click on apply and open it again, it's OK. But when I clic on Savel all changes in Manage connections dialog it replaces <, >, and " with &lt; &gt; and &quot;. It replaces these characters after each save.
Can you fix this pleas?
Best wishes,
Vaclav
xml01.pngPasted XMLxml02.pngXML after the first savexml03.pngXML after the second save
1 - 1 of 11
    User: "Vaclav"
    OP
    Now I also noticed that ParameterTypeList does not work properly. Is there any workaround for this?
    Thanks for any advice.
    Vaclav
