🎉Community Raffle - Win $25
Join and Win
Decision Tree Operator - C5 or C4.5 algorithm?
User: "cwerning"
New Altair Community Member
Updated by Jocelyn
Hello experts,
does RM still uses the C4.5 algorithm for his decision tree operator? I found some really old topics that say it uses the C4.5 algorithm.
Kind regards,
Christopher
1 - 10 of 101
    User: "MartinLiebig"
    Altair Employee
    Accepted Answer
    The shipped descion tree is actually a own implemtation. I am not sure if it follows any direct implementation, i think it is some mixture, but I am not sure.
    If you want to have C4.5 you may have a look on W-J48.
    ~Martin
    Edit: Just looked it up:
     * <p>
    * This operator learns decision trees from both nominal and numerical data. Decision trees are
    * powerful classification methods which often can also easily be understood. This decision tree
    * learner works similar to Quinlan's C4.5 or CART.
    * </p>
    * <p>
    * The actual type of the tree is determined by the criterion, e.g. using gain_ratio or Gini for
    * CART / C4.5.
    * </p>
    User: "cwerning"
    OP
    Hi Martin,
    thank your very much for your help! But where did you found the information? Is it from a public source which I dond know? I can not find the information in operators manual.
    Kind regards,
    Christopher
    Dear Christopher,
    i copied it from the source code. It is available at https://github.com/rapidminer/rapidminer-studio/blob/master/src/main/java/com/rapidminer/operator/learner/tree/ParallelDecisionTreeLearner.java . Im a bit unsure where this comment pops up in studio.
    ~Martin
    User: "Telcontar120"
    If you get the Weka extension (which is free and highly recommended, since it has over a hundred predictive modeling operators) then you will have access to several different flavors of decision tree operators, including the weka implementation of the C4.5 algorithm in the W-J48 operator.
    User: "Fred12"
    so I guess the C5.0 is not yet implemented in Rapidminer?
    User: "accounting1100"
    Hi
    Where can i find C5 in Rapid Miner? It's not in the decision tree section?
    User: "Thomas_Ott"
    You'll need to download the Weka extension to get it.
    User: "Fred12"
    but I think C5.0 is too new and still under license to be implemented in rapidminer or weka yet, is that true?
    its only C4.5 in Weka I think...
    User: "thatharpandi199"
    I am Thathar
    shall I use C4.5 algorithm in Rapidminer?
    User: "sgenzer"
    Altair Employee
    hello @thatharpandi199 - I would use the normal Decision Tree operator in Studio Core. It is the best by far. :)
    Scott
