🎉Community Raffle - Win $25
Join and Win
Thermal study of the rotating brake disc
User: "Gabriel Rodrigues"
Altair Community Member
Updated by Gabriel Rodrigues
I'm doing the thermal of this brake disc and I'm not getting what I expected. I need to simulate this brake disc running at 60 km/h and stopping in 1.1 seconds. But the simulation is heavy and is not giving me the expected values
1 - 3 of 31
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    Could you add a few more details on what exactly you're trying? and what happened, in order to give more details so that more people could help. Also adding some pictures could be helpful.
    OP
    I need to simulate a brake disc spinning and the pads applying pressure to lock the disc. The disk rotates around the axis at 60 km/h. I need to simulate for 1.1 seconds which is the milling time of the car and find the maximum temperature
    Altair Employee
    I believe you have seen this example in the Radioss documentation, right?
    Not sure if it can help you.
    https://help.altair.com/hwsolvers/rad/topics/solvers/rad/brake_example_r.htm#brake_example_r
