[SOLVED] How to create a "real table" from a "virtual table"?
Hi,
I'm trying to extract data from a database that stores information in "virtual tables".
This is how the data looks in the database:
In this layout, I can not access the information properly, so I'm trying to create a "classic" table, which should look like this:
Both tables contain exactly the same information, client 1 has two names assigned in this list, and client 2 (in green) has only one.
I somehow believe that one of the "Loop" operators might be able to achieve that, but I couldn't figure it out.
Could someone please help me to "transpose" the first table into the second one?
Thank you very much!!
client_id | recordset_id | column_header | value |
1 | 1000 | Name | John |
1 | 1000 | City | Toronto |
1 | 1000 | Province | ON |
1 | 1001 | Name | Michael |
1 | 1001 | City | Vancouver |
1 | 1001 | Province | BC |
2 | 1002 | Name | Rene |
2 | 1002 | City | Montreal |
2 | 1002 | Province | QC |
client_id | recordset_id | Name | City | Province |
1 | 1000 | John | Toronto | ON |
1 | 1001 | Michael | Vancouver | BC |
2 | 1002 | Rene | Montreal | QC |
1 - 3 of
31
Hi Martin,
thanks a lot for your answer! Maybe I'm not (yet) seeing the full scope of the pivot operator. As far as I see, it only allows for two variables (one for each line, one for the header). But what I would need the operator to create a one column for client, one for record ID, and then it needs to pivot whichever column header it finds.
Am I missing something, and the pivot operator can actually do this?
Thanks a again for your answer!
Hi Martin,
thanks again for your reply!
You were right, the Pivot operator does the trick. My error was that I tried to do too many things in one single step, while the PIVOT operator only allows for 3 incoming variables.
I simply split the workflow now with the "Multiply" operator. In one stream, I find all unique clientID - recordID combinations, and in the other stream I pivot the table so that I get one line per recordID, with all possible different headers. Then I join the two streams, and I get exactly what I was looking for.
Thanks again for putting me on the right track!
RapidMiner rocks
RapidMiner rocks
the operator you search for is Pivot. Just have a look at the help of the operator. It is always a bit confusing but helpful.
Cheers,
Martin
