"Google Maps API"
hi...not sure if someone has done this before but I figured out how to get Google Maps API to work within RM. This operator takes an address (attribute="address_for_google") and calculates the distance in miles to New York, NY. Note that if you use this, you will need to request an API key from developer.google.com
<operator activated="true" class="web:enrich_data_by_webservice" compatibility="5.3.002" expanded="true" height="60" name="Google Maps Distance Lookup" width="90" x="313" y="30">
<parameter key="query_type" value="XPath"/>
<list key="string_machting_queries"/>
<list key="regular_expression_queries"/>
<list key="regular_region_queries"/>
<list key="xpath_queries">
<parameter key="Distance" value="//distance/text/text()"/>
</list>
<list key="namespaces"/>
<parameter key="assume_html" value="false"/>
<list key="index_queries"/>
<list key="jsonpath_queries"/>
<parameter key="service_method" value="fgfgfgf"/>
<parameter key="body" value="text=<%title%>"/>
<parameter key="url" value=""/>
<parameter key="delay" value="20"/>
<list key="request_properties">
<parameter key="key" value="ENTER YOUR API KEY HERE"/>
</list>
</operator>
1 - 3 of
31
cool, thanks for sharing
Regards,
Marco
