🎉Community Raffle - Win $25
Join and Win
Radoop Error: could not upload the necessary components to the directory of HDFS
User: "kimusu2002"
New Altair Community Member
Updated by Jocelyn
Hi,
I am having problem with this Radoop Error: could not upload the necessary components to the directory of HDFS. It said that the radoop can't upload into the directory ''/tmp/radoop/27eca174758add21906d3b197af684e7/ ' .
So I changed the permission of "'/tmp/radoop/" and also '/tmp/radoop/27eca174758add21906d3b197af684e7/ ' of the namenode in VM, and then I typed in 'hadoop fs -ls /tmp/radoop", results show that the permission had been changed. So I went ahead and re-run the process which has the "Radoop nest", and the same error pop out again, and the permission of the directory "tmp/radoop" is now changed back automatically to the one before.
Could some give me some pointers please ?  :D
FYI, i was able to connect the cluster, and also able to explore all the HIVE tables.
Thanks heaps !
