🎉Community Raffle - Win $25
Join and Win
forever show JBoss AS 7.2.0.Alpha1-redhat-4 "Janus" starting
User: "yongie"
New Altair Community Member
Updated by Jocelyn
Hi
I just tried to setup Rapidminer server on Centos 6.6 machine, everything seems fine, but when I start the server using standalone.sh, the terminal show the following forever, I could not access the server through the browser.
14:37:12,505 INFO  [org.jboss.as] (MSC service thread 1-7) JBAS015899: JBoss AS 7.2.0.Alpha1-redhat-4 "Janus" starting
The content of the log:
09:54:43,767 INFO  [org.jboss.modules] (main) JBoss Modules version 1.2.0.CR1
09:54:43,959 INFO  [org.jboss.msc] (main) JBoss MSC version 1.0.4.GA
09:54:44,031 INFO  [org.jboss.as] (MSC service thread 1-7) JBAS015899: JBoss AS 7.2.0.Alpha1-redhat-4 "Janus" starting
09:54:44,038 DEBUG [org.jboss.as.config] (MSC service thread 1-7) Configured system properties:
[Standalone] =
awt.toolkit = sun.awt.X11.XToolkit
file.encoding = UTF-8
file.encoding.pkg = sun.io
file.separator = /
java.awt.graphicsenv = sun.awt.X11GraphicsEnvironment
java.awt.headless = true
java.awt.printerjob = sun.print.PSPrinterJob
java.class.path = /root/jboss-modules.jar
java.class.version = 52.0
java.endorsed.dirs = /usr/java/jdk1.8.0_40/jre/lib/endorsed
java.ext.dirs = /usr/java/jdk1.8.0_40/jre/lib/ext:/usr/java/packages/lib/ext
java.home = /usr/java/jdk1.8.0_40/jre
java.io.tmpdir = /tmp
java.library.path = /usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib
java.net.preferIPv4Stack = true
java.runtime.name = Java(TM) SE Runtime Environment
java.runtime.version = 1.8.0_40-b25
java.specification.name = Java Platform API Specification
java.specification.vendor = Oracle Corporation
java.specification.version = 1.8
java.util.logging.manager = org.jboss.logmanager.LogManager
java.vendor = Oracle Corporation
java.vendor.url = http://java.oracle.com/
java.vendor.url.bug = http://bugreport.sun.com/bugreport/
java.version = 1.8.0_40
java.vm.info = mixed mode
java.vm.name = Java HotSpot(TM) 64-Bit Server VM
java.vm.specification.name = Java Virtual Machine Specification
java.vm.specification.vendor = Oracle Corporation
java.vm.specification.version = 1.8
java.vm.vendor = Oracle Corporation
java.vm.version = 25.40-b25
javax.management.builder.initial = org.jboss.as.jmx.PluggableMBeanServerBuilder
javax.xml.datatype.DatatypeFactory = __redirected.__DatatypeFactory
javax.xml.parsers.DocumentBuilderFactory = __redirected.__DocumentBuilderFactory
javax.xml.parsers.SAXParserFactory = __redirected.__SAXParserFactory
javax.xml.stream.XMLEventFactory = __redirected.__XMLEventFactory
javax.xml.stream.XMLInputFactory = __redirected.__XMLInputFactory
javax.xml.stream.XMLOutputFactory = __redirected.__XMLOutputFactory
javax.xml.transform.TransformerFactory = __redirected.__TransformerFactory
javax.xml.validation.SchemaFactory:http://www.w3.org/2001/XMLSchema = __redirected.__SchemaFactory
javax.xml.xpath.XPathFactory:http://java.sun.com/jaxp/xpath/dom = __redirected.__XPathFactory
jboss.home.dir = /root
jboss.host.name = localhost
jboss.modules.dir = /root/modules
jboss.modules.system.pkgs = org.jboss.byteman
jboss.node.name = localhost
jboss.qualified.host.name = localhost.localdomain
jboss.server.base.dir = /root/standalone
jboss.server.config.dir = /root/standalone/configuration
jboss.server.data.dir = /root/standalone/data
jboss.server.default.config = standalone.xml
jboss.server.deploy.dir = /root/standalone/data/content
jboss.server.log.dir = /root/standalone/log
jboss.server.name = localhost
jboss.server.persist.config = true
jboss.server.temp.dir = /root/standalone/tmp
line.separator =
logging.configuration = file:/root/standalone/configuration/logging.properties
module.path = /root/modules
org.jboss.boot.log.file = /root/standalone/log/server.log
org.jboss.resolver.warning = true
org.xml.sax.driver = __redirected.__XMLReaderFactory
os.arch = amd64
os.name = Linux
os.version = 2.6.32-504.8.1.el6.x86_64
path.separator = :
sun.arch.data.model = 64
sun.boot.class.path = /usr/java/jdk1.8.0_40/jre/lib/resources.jar:/usr/java/jdk1.8.0_40/jre/lib/rt.jar:/usr/java/jdk1.8.0_40/jre/lib/sunrsasign.jar:/usr/java/jdk1.8.0_40/jre/lib/jsse.jar:/usr/java/jdk1.8.0_40/jre/lib/jce.jar:/usr/java/jdk1.8.0_40/jre/lib/charsets.jar:/usr/java/jdk1.8.0_40/jre/lib/jfr.jar:/usr/java/jdk1.8.0_40/jre/classes:/root/jboss-modules.jar
sun.boot.library.path = /usr/java/jdk1.8.0_40/jre/lib/amd64
sun.cpu.endian = little
sun.cpu.isalist =
sun.desktop = gnome
sun.io.unicode.encoding = UnicodeLittle
sun.java.command = /root/jboss-modules.jar -mp /root/modules -jaxpmodule javax.xml.jaxp-provider org.jboss.as.standalone -Djboss.home.dir=/root -Djboss.server.base.dir=/root/standalone
sun.java.launcher = SUN_STANDARD
sun.jnu.encoding = UTF-8
sun.management.compiler = HotSpot 64-Bit Tiered Compilers
sun.os.patch.level = unknown
sun.rmi.dgc.client.gcInterval = 3600000
sun.rmi.dgc.server.gcInterval = 3600000
user.country = US
user.dir = /root/bin
user.home = /root
user.language = en
user.name = root
user.timezone = Asia/Kuala_Lumpur
09:54:44,039 DEBUG [org.jboss.as.config] (MSC service thread 1-7) VM Arguments: -D[Standalone] -XX:+UseCompressedOops -Xms512m -Xmx1024m -XX:MaxPermSize=256m -XX:+UseG1GC -XX:MaxGCPauseMillis=50 -Djava.net.preferIPv4Stack=true -Dorg.jboss.resolver.warning=true -Dsun.rmi.dgc.client.gcInterval=3600000 -Dsun.rmi.dgc.server.gcInterval=3600000 -Djboss.modules.system.pkgs=org.jboss.byteman -Djava.awt.headless=true -Djboss.server.default.config=standalone.xml -Dorg.jboss.boot.log.file=/root/standalone/log/server.log -Dlogging.configuration=file:/root/standalone/configuration/logging.properties -Xbootclasspath/a:/root/jboss-modules.jar
09:57:56,051 INFO  [org.jboss.as] (MSC service thread 1-9) JBAS015950: JBoss AS 7.2.0.Alpha1-redhat-4 "Janus" stopped in 8ms
09:58:01,945 INFO  [org.jboss.modules] (main) JBoss Modules version 1.2.0.CR1
09:58:02,108 INFO  [org.jboss.msc] (main) JBoss MSC version 1.0.4.GA
09:58:02,174 INFO  [org.jboss.as] (MSC service thread 1-7) JBAS015899: JBoss AS 7.2.0.Alpha1-redhat-4 "Janus" starting
09:58:02,182 DEBUG [org.jboss.as.config] (MSC service thread 1-7) Configured system properties:
[Standalone] =
file.separator = /
line.separator =
os.arch = amd64
os.name = Linux
path.separator = :
sun.cpu.isalist =
sun.desktop = gnome
user.country = US
user.home = /root
user.language = en
user.name = root
09:58:02,183 DEBUG [org.jboss.as.config] (MSC service thread 1-7) VM Arguments: -D[Standalone] -XX:+UseCompressedOops -Xms512m -Xmx1024m -XX:MaxPermSize=256m -XX:+UseG1GC -XX:MaxGCPauseMillis=50 -Djava.net.preferIPv4Stack=true -Dorg.jboss.resolver.warning=true -Dsun.rmi.dgc.client.gcInterval=3600000 -Dsun.rmi.dgc.server.gcInterval=3600000 -Djboss.modules.system.pkgs=org.jboss.byteman -Djava.awt.headless=true -Djboss.server.default.config=standalone.xml -Dorg.jboss.boot.log.file=/root/standalone/log/server.log -Dlogging.configuration=file:/root/standalone/configuration/logging.properties -Xbootclasspath/a:/root/jboss-modules.jar
09:59:20,553 INFO  [org.jboss.as] (MSC service thread 1-10) JBAS015950: JBoss AS 7.2.0.Alpha1-redhat-4 "Janus" stopped in 7ms
14:37:12,180 INFO  [org.jboss.modules] (main) JBoss Modules version 1.2.0.CR1
14:37:12,428 INFO  [org.jboss.msc] (main) JBoss MSC version 1.0.4.GA
14:37:12,511 DEBUG [org.jboss.as.config] (MSC service thread 1-7) Configured system properties:
[Standalone] =
file.separator = /
line.separator =
os.arch = amd64
os.name = Linux
path.separator = :
sun.cpu.isalist =
sun.desktop = gnome
user.country = US
user.home = /root
user.language = en
user.name = root
14:37:12,512 DEBUG [org.jboss.as.config] (MSC service thread 1-7) VM Arguments: -D[Standalone] -XX:+UseCompressedOops -Xms512m -Xmx1024m -XX:MaxPermSize=256m -XX:+UseG1GC -XX:MaxGCPauseMillis=50 -Djava.net.preferIPv4Stack=true -Dorg.jboss.resolver.warning=true -Dsun.rmi.dgc.client.gcInterval=3600000 -Dsun.rmi.dgc.server.gcInterval=3600000 -Djboss.modules.system.pkgs=org.jboss.byteman -Djava.awt.headless=true -Djboss.server.default.config=standalone.xml -Dorg.jboss.boot.log.file=/root/standalone/log/server.log -Dlogging.configuration=file:/root/standalone/configuration/logging.properties -Xbootclasspath/a:/root/jboss-modules.jar
1 - 2 of 21
    User: "Marco_Boeck"
    Hi,
    you are using Java 8. That is currently not supported by the Server. Please use the latest Java 7 instead. You can change the chosen Java version during installation of the Server.
    Regards,
    Marco
    User: "yongie"
    OP
    Thanks! got it!
