Elements not defined in template error
Hi,
I created a mesh in HyperMesh and i would like to export it in .unv format.I chose ideas template for export. But as I saw in the ideas file there is no pyramid elements (I have them in my mesh). So I did as you wrote here :
I created a pyra.tpl and I included it in my ideas file. But it still doesn't work and I don't have any pyramides. Have you any idea of how to fix it?
Hi,
By using your 'pyra.tpl', I got the following output:
CPYRAM 334 5 335 342 337 336 343 CPYRAM 335 5 335 334 340 342 346 CPYRAM 336 5 337 342 341 338 345 CPYRAM 337 5 342 340 339 341 344 CPYRAM 347 5 348 355 350 349 356 364 370 367 363 365 384 371 368 CPYRAM 348 5 348 347 353 355 359 360 361 378 364 366 362 380 387 CPYRAM 349 5 350 355 354 351 358 370 381 373 369 372 386 383 374 CPYRAM 350 5 355 353 352 354 357 378 375 376 381 385 379 377 382
So I think this template works /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
I think, it doesn't work because ideas does not support pyramide elements. So I will export in nastran and convert after.
