1 - 5 of
51
I only saw a C implementation of it. Is there a Java implementation?
If so you might be able to add it to rapidminer. If you are familiar with java Rapidminer is easy to extend.
You can find a guide here: http://rapidminer.com/wp-content/uploads/2013/10/How-to-Extend-RapidMiner-5.pdf
Of course feel free to ask questions
Thanks!
There is a Java wrapper for SVM light in C (example: http://nlp.stanford.edu/nlp/javadoc/jsvm/jsvm.Svm.html)
Would this make it easier?
Regards
Regards
Small update here:
actually the standard SVM of rapidminer seems to use SVM-Light. The SVM is calling mySVM by Stefan Rüping. This is using the SVM light implimentation. See: http://www-ai.cs.uni-dortmund.de/SOFTWARE/MYSVM/index.html
Why can't you use the standard RapidMiner SVMs?
