"[SOLVED] Filtering examples containing multiple attributes with a blacklist"
scepxkoUser: "scepxko"
New Altair Community Member
Updated by Jocelyn
Hi everyone,
I'm stuck on something since several hours and can't definitely find the solution by myself.
I've searched for a solution on the forum without any success so far.
Here's the situation:
- The source file is an Excel file "input.xls" containing 4 columns/attributes:
ID ---- industry --- location ------- title
111 xyz Cayman Islands xyz
222 xyz Peru xyz
333 xyz USA xyz
- I want to remove the lines whose attribute "location" has a value contained in a blacklist "location-to-filter-out.xls".
This Excel file looks like
location2
Cayman
France
USA
- Then save the filtered file as "output.xls". Here it would look like:
222 xyz Peru xyz
What I have done so far:
- In the code below, I have a "Loop Attributes" on "location"
- Inside it (subprocess), I have a "Read Excel" operator, extracting the "location2" values from the blacklist. And a second "Loop attributes" running on "location2" this time.
- Inside this second "Loop attributes" (sub-subprocess), I have the filtering condition with the operator "Filter Examples", with the condition class "attribute_value_filter".
The parameter string is: %{loop_attribute}=(.*?)%{loop_attribute2}(.*?)
Where the %{loop_attribute} is the original attribute "location" in the source file. For example "Cayman Islands".
And %{loop_attribute2} is a location blacklisted. For example "Cayman" (the blacklist contains only single words for the sake of simplicity. That's why I use "(.*?)" in the filtering condition.
Problem:
It does not work and I'm unable to find the flaw in my logic.
Maybe can somebody enlighten me?
Thanks in advance for your help.
Alex
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.3.015">
 <context>
   <input/>
   <output/>
   <macros/>
 </context>
 <operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process">
   <process expanded="true">
     <operator activated="true" class="read_excel" compatibility="5.3.015" expanded="true" height="60" name="Read Excel (3)" width="90" x="45" y="30">
       <parameter key="excel_file" value="E:\Rapidminer\example\input.xls"/>
       <parameter key="imported_cell_range" value="A1:G650"/>
       <parameter key="first_row_as_names" value="false"/>
       <list key="annotations">
         <parameter key="0" value="Name"/>
       </list>
       <list key="data_set_meta_data_information">
         <parameter key="0" value="ID.true.integer.attribute"/>
         <parameter key="1" value="industry.true.polynominal.attribute"/>
         <parameter key="2" value="location.true.polynominal.attribute"/>
         <parameter key="3" value="title.true.polynominal.attribute"/>
       </list>
     </operator>
     <operator activated="true" class="loop_attributes" compatibility="5.3.015" expanded="true" height="94" name="Loop Attributes" width="90" x="514" y="30">
       <parameter key="attribute_filter_type" value="single"/>
       <parameter key="attribute" value="location"/>
         <operator activated="true" class="read_excel" compatibility="5.3.015" expanded="true" height="60" name="Read Excel (4)" width="90" x="246" y="165">
           <parameter key="excel_file" value="E:\Rapidminer\example\location-to-filter-out.xls"/>
           <parameter key="imported_cell_range" value="A1:E67"/>
           </list>
             <parameter key="0" value="location2.true.polynominal.attribute"/>
           </list>
         </operator>
         <operator activated="true" class="loop_attributes" compatibility="5.3.015" expanded="true" height="76" name="Loop Attributes (2)" width="90" x="514" y="165">
           <parameter key="attribute" value="location2"/>
           <parameter key="iteration_macro" value="loop_attribute2"/>
             <operator activated="true" class="filter_examples" compatibility="5.3.015" expanded="true" height="76" name="Filter Examples (3)" width="90" x="447" y="30">
               <parameter key="condition_class" value="attribute_value_filter"/>
               <parameter key="parameter_string" value="%{loop_attribute}=(.*?)%{loop_attribute2}(.*?)"/>
               <parameter key="invert_filter" value="true"/>
             </operator>
             <connect from_port="example set" to_op="Filter Examples (3)" to_port="example set input"/>
             <connect from_op="Filter Examples (3)" from_port="example set output" to_port="example set"/>
             <portSpacing port="source_example set" spacing="0"/>
             <portSpacing port="sink_example set" spacing="0"/>
           </process>
         </operator>
         <connect from_port="example set" to_port="example set"/>
         <connect from_op="Read Excel (4)" from_port="output" to_op="Loop Attributes (2)" to_port="example set"/>
         <connect from_op="Loop Attributes (2)" from_port="example set" to_port="result 1"/>
       </process>
     </operator>
     <operator activated="true" class="write_excel" compatibility="5.3.015" expanded="true" height="76" name="Write Excel" width="90" x="849" y="30">
       <parameter key="excel_file" value="E:\Rapidminer\example\output.xls"/>
     </operator>
     <connect from_op="Read Excel (3)" from_port="output" to_op="Loop Attributes" to_port="example set"/>
     <connect from_op="Loop Attributes" from_port="example set" to_op="Write Excel" to_port="input"/>
     <connect from_op="Write Excel" from_port="through" to_port="result 1"/>
   </process>
 </operator>
</process>
1 - 8 of 81
    1. Read in both "input.xls"  and "location-to-filter-out.xls"
    2. Do a left join where location=location2 (with input.xls going to the left input) and select "keep both join attributes".
    3. Use filter examples to filter for examples that are missing location2.
    Hope this helps!
    OP
    Thank you, it helped to go further.
    So here with the updated code below, if I have an exact match between the attribute "location" and the blacklisted attribute "location2", the example is removed.
    Problem: it only works with an exact match.
    I would like to filter the attribute "location" using a wildcard, like this %{location}=(.*?)%{location2}(.*?)
    If I put "India" in the blacklist, it would remove the example with "Gurgaon, India", "Delhi, India" etc.
    Any idea?
    Thanks again
     <context>
       <input/>
       <output/>
       <macros/>
     </context>
           </list>
           </list>
         </operator>
         <operator activated="true" class="read_excel" compatibility="5.3.015" expanded="true" height="60" name="Read Excel (2)" width="90" x="45" y="165">
           </list>
           </list>
         </operator>
         <operator activated="true" class="join" compatibility="5.3.015" expanded="true" height="76" name="Join" width="90" x="246" y="165">
           <parameter key="join_type" value="left"/>
           <parameter key="use_id_attribute_as_key" value="false"/>
           <list key="key_attributes">
             <parameter key="location" value="location2"/>
           </list>
           <parameter key="keep_both_join_attributes" value="true"/>
         </operator>
         <operator activated="true" class="filter_examples" compatibility="5.3.015" expanded="true" height="76" name="Filter Examples (2)" width="90" x="447" y="165">
           <parameter key="condition_class" value="no_missing_attributes"/>
           <parameter key="parameter_string" value="location=(.*?)location2(.*?)"/>
         </operator>
         <operator activated="true" class="select_attributes" compatibility="5.3.015" expanded="true" height="76" name="Select Attributes" width="90" x="648" y="165">
           <parameter key="attribute_filter_type" value="subset"/>
           <parameter key="attributes" value="|ID|industry|location|title"/>
         </operator>
         <operator activated="true" class="write_excel" compatibility="5.3.015" expanded="true" height="76" name="Write Excel" width="90" x="849" y="165">
         </operator>
         <connect from_op="Read Excel (3)" from_port="output" to_op="Join" to_port="left"/>
         <connect from_op="Read Excel (2)" from_port="output" to_op="Join" to_port="right"/>
         <connect from_op="Join" from_port="join" to_op="Filter Examples (2)" to_port="example set input"/>
         <connect from_op="Filter Examples (2)" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
         <connect from_op="Select Attributes" from_port="example set output" to_op="Write Excel" to_port="input"/>
       </process>
     </operator>
    </process>
    Version 6 of RapidMiner, the Filter Examples operator lets you filter based on partial matches.
    Andrew
    OP
    Hi Andrew,
    First I own your book. I wish I had it 3 years ago when I started to play with Rapidminer. Thank you for your work
    As for your suggestion, yes, RM6 has this more advanced filtering option.
    I just tried it with "contains" and "matches" and I don't get the result wished.
    In RM5, I introduced a new attribute "ToRemove" that compares the values of "location" and "location2", and then I filtered the examples with the ToRemove values of true/false.
    That's a method I saw in other posts.
    I tried "finds", "matches", and "if".
    Here are my results:
    ** Filters only the exact match (see my first post, it would remove the "USA" row, but not the "Cayman" row)
    finds(location,location2)
    finds(location,%{location2})
    matches(location,location2)
    matches(location,%{location2})
    matches(location,".*%{location2}.*")
    if((location==location2), true, false)
    ** Filters nothing at all (input and output files identical)
    finds(location,"%{location2}")
    finds(location,".*%{location2}.*")
    if((location==".*location2.*"), true, false)
    if((%{location}==".*%{location2}.*"), true, false)
    if((%{location}=="(.*?)%{location2}(.*?)"), true, false)
    I am surely doing something wrong with the wildcards but I have really no idea what it is.
    Any idea?
    Thank you in advance
     <context>
       <input/>
       <output/>
       <macros/>
     </context>
           </list>
           </list>
         </operator>
           </list>
           </list>
         </operator>
           </list>
         </operator>
         <operator activated="true" class="generate_attributes" compatibility="5.3.015" expanded="true" height="76" name="Generate Attributes" width="90" x="380" y="165">
           <list key="function_descriptions">
             <parameter key="toRemove" value="finds(location,location2)"/>
           </list>
         </operator>
         <operator activated="true" class="filter_examples" compatibility="5.3.015" expanded="true" height="76" name="Filter Examples (2)" width="90" x="514" y="165">
           <parameter key="parameter_string" value="toRemove != true"/>
         </operator>
         </operator>
         <connect from_op="Join" from_port="join" to_op="Generate Attributes" to_port="example set input"/>
         <connect from_op="Generate Attributes" from_port="example set output" to_op="Filter Examples (2)" to_port="example set input"/>
         <connect from_op="Filter Examples (2)" from_port="example set output" to_op="Write Excel" to_port="input"/>
       </process>
     </operator>
    </process>
    Hello
    Thanks for the thanks about the book!
    You could try a right join like in the following.
    <process version="6.1.000">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="6.1.000" expanded="true" name="Process">
          <operator activated="true" class="retrieve" compatibility="6.1.000" expanded="true" height="60" name="Retrieve Iris" width="90" x="179" y="75">
            <parameter key="repository_entry" value="//Samples/data/Iris"/>
          </operator>
          <operator activated="true" class="generate_data_user_specification" compatibility="6.1.000" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="179" y="210">
            <list key="attribute_values">
              <parameter key="label" value="&quot;Iris-setosa&quot;"/>
            </list>
            <list key="set_additional_roles"/>
          </operator>
          <operator activated="true" class="join" compatibility="6.1.000" expanded="true" height="76" name="Join" width="90" x="447" y="75">
            <parameter key="join_type" value="right"/>
              <parameter key="label" value="label"/>
            </list>
          </operator>
          <connect from_op="Retrieve Iris" from_port="output" to_op="Join" to_port="left"/>
          <connect from_op="Generate Data by User Specification" from_port="output" to_op="Join" to_port="right"/>
          <connect from_op="Join" from_port="join" to_port="result 1"/>
        </process>
      </operator>
    </process>
    regards
    Andrew
    OP
    Hi Andrew,
    Thank you for helping again.
    that's what I did with the post #3 and I'm afraid it doesn't work.
    I need to find a solution for this wildcards to work.
    Maybe go again in the direction of a Loop subprocess for each attribute "location" in the input file.
    Otherwise I'm out of resources.
    Black Friday for inspiration!
    Hello scepxko
    Here is one solution - the trick is to use the Cartesian operator - this might cause memory explosions - be brave. Memory saving is something I know a lot about so report back with progress.
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
          <operator activated="true" class="subprocess" compatibility="6.1.000" expanded="true" height="76" name="source" width="90" x="112" y="75">
              <operator activated="true" class="generate_data_user_specification" compatibility="6.1.000" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="112" y="120">
                  <parameter key="country" value="&quot;Cayman Islands&quot;"/>
                </list>
              </operator>
              <operator activated="true" class="generate_data_user_specification" compatibility="6.1.000" expanded="true" height="60" name="Generate Data by User Specification (2)" width="90" x="112" y="210">
                  <parameter key="country" value="&quot;Peru&quot;"/>
                </list>
              </operator>
              <operator activated="true" class="generate_data_user_specification" compatibility="6.1.000" expanded="true" height="60" name="Generate Data by User Specification (3)" width="90" x="112" y="300">
                  <parameter key="country" value="&quot;USA&quot;"/>
                </list>
              </operator>
              <operator activated="true" class="append" compatibility="6.1.000" expanded="true" height="112" name="Append" width="90" x="313" y="120"/>
              <connect from_op="Generate Data by User Specification" from_port="output" to_op="Append" to_port="example set 1"/>
              <connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Append" to_port="example set 2"/>
              <connect from_op="Generate Data by User Specification (3)" from_port="output" to_op="Append" to_port="example set 3"/>
              <connect from_op="Append" from_port="merged set" to_port="out 1"/>
              <portSpacing port="source_in 1" spacing="0"/>
              <portSpacing port="sink_out 1" spacing="0"/>
              <portSpacing port="sink_out 2" spacing="0"/>
            </process>
          </operator>
          <operator activated="true" class="subprocess" compatibility="6.1.000" expanded="true" height="76" name="remove" width="90" x="112" y="165">
              <operator activated="true" class="generate_data_user_specification" compatibility="6.1.000" expanded="true" height="60" name="Generate Data by User Specification (4)" width="90" x="112" y="75">
                  <parameter key="country" value="&quot;Cayman&quot;"/>
                </list>
              </operator>
              <operator activated="true" class="generate_data_user_specification" compatibility="6.1.000" expanded="true" height="60" name="Generate Data by User Specification (5)" width="90" x="112" y="165">
                  <parameter key="country" value="&quot;France&quot;"/>
                </list>
              </operator>
              <operator activated="true" class="generate_data_user_specification" compatibility="6.1.000" expanded="true" height="60" name="Generate Data by User Specification (6)" width="90" x="112" y="255">
                </list>
              </operator>
              <operator activated="true" class="append" compatibility="6.1.000" expanded="true" height="112" name="Append (2)" width="90" x="313" y="75"/>
              <connect from_op="Generate Data by User Specification (4)" from_port="output" to_op="Append (2)" to_port="example set 1"/>
              <connect from_op="Generate Data by User Specification (5)" from_port="output" to_op="Append (2)" to_port="example set 2"/>
              <connect from_op="Generate Data by User Specification (6)" from_port="output" to_op="Append (2)" to_port="example set 3"/>
              <connect from_op="Append (2)" from_port="merged set" to_port="out 1"/>
            </process>
          </operator>
          <operator activated="true" class="cartesian_product" compatibility="6.1.000" expanded="true" height="76" name="Cartesian" width="90" x="246" y="75">
            <parameter key="remove_double_attributes" value="false"/>
          </operator>
          <operator activated="true" class="generate_attributes" compatibility="6.1.000" expanded="true" height="76" name="Generate Attributes" width="90" x="380" y="75">
              <parameter key="deleteme" value="if(matches(country,&quot;.*&quot;+country_from_ES2+&quot;.*&quot;),1,0)"/>
            </list>
          </operator>
          <operator activated="true" class="aggregate" compatibility="6.1.000" expanded="true" height="76" name="Aggregate" width="90" x="514" y="75">
            <list key="aggregation_attributes">
              <parameter key="deleteme" value="sum"/>
            </list>
            <parameter key="group_by_attributes" value="country"/>
          </operator>
          <operator activated="true" class="filter_examples" compatibility="6.1.000" expanded="true" height="94" name="Filter Examples" width="90" x="648" y="75">
            <list key="filters_list">
              <parameter key="filters_entry_key" value="sum(deleteme).eq.0"/>
            </list>
          </operator>
          <operator activated="true" class="select_attributes" compatibility="6.1.000" expanded="true" height="76" name="Select Attributes" width="90" x="782" y="75">
            <parameter key="attributes" value="country"/>
          </operator>
          <connect from_op="source" from_port="out 1" to_op="Cartesian" to_port="left"/>
          <connect from_op="remove" from_port="out 1" to_op="Cartesian" to_port="right"/>
          <connect from_op="Cartesian" from_port="join" to_op="Generate Attributes" to_port="example set input"/>
          <connect from_op="Generate Attributes" from_port="example set output" to_op="Aggregate" to_port="example set input"/>
          <connect from_op="Aggregate" from_port="example set output" to_op="Filter Examples" to_port="example set input"/>
          <connect from_op="Filter Examples" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
          <connect from_op="Select Attributes" from_port="example set output" to_port="result 1"/>
        </process>
      </operator>
    </process>
    Good luck!
    regards
    Andrew
    OP
    Accepted Answer
    Hi Andrew.
    You saved me.
    Using the Cartesian operator was one of the working solutions.
    As for the resources, I am currently processing 22'000 examples.
    And by launching the processes via command-line, I can make batches of 1400 examples at a time (in the final process, one example has 8 attributes, and there are 4 filtering processes).
    When I go above 1400, I simply get no results.
    But it's fine to me, it will take less than 30 minutes to process it all, whereas I spent +5 hours this week looking for a solution to this filtering issue!!
    Thanks again Andrew, enjoy this weekend fully, you deserve it :-)
    Alex
    PS: For those having a similar challenge to solve, I copy/paste below the working code.
     <context>
       <input/>
       <output/>
       <macros/>
     </context>
           <parameter key="imported_cell_range" value="A1:G1000"/>
           </list>
           </list>
         </operator>
         <operator activated="true" class="read_excel" compatibility="5.3.015" expanded="true" height="60" name="Read Excel (2)" width="90" x="45" y="120">
           <parameter key="imported_cell_range" value="A1:E1000"/>
           </list>
           </list>
         </operator>
         <operator activated="true" class="cartesian_product" compatibility="5.3.015" expanded="true" height="76" name="Cartesian" width="90" x="246" y="30"/>
         <operator activated="true" class="generate_attributes" compatibility="5.3.015" expanded="true" height="76" name="Generate Attributes" width="90" x="380" y="30">
             <parameter key="toRemove" value="if(matches(location,&quot;.*&quot;+location2+&quot;.*&quot;),1,0)"/>
           </list>
         </operator>
         <operator activated="true" class="aggregate" compatibility="5.3.015" expanded="true" height="76" name="Aggregate" width="90" x="514" y="30">
             <parameter key="toRemove" value="sum"/>
           </list>
           <parameter key="group_by_attributes" value="industry|location|title|ID"/>
         </operator>
         <operator activated="true" class="filter_examples" compatibility="5.3.015" expanded="true" height="76" name="Filter Examples (2)" width="90" x="648" y="30">
           <parameter key="parameter_string" value="sum(toRemove)!=1"/>
         </operator>
         <operator activated="true" class="select_attributes" compatibility="5.3.015" expanded="true" height="76" name="Select Attributes" width="90" x="782" y="30">
           <parameter key="attributes" value="industry|location|title||ID"/>
         </operator>
         <operator activated="true" class="write_excel" compatibility="5.3.015" expanded="true" height="76" name="Write Excel" width="90" x="916" y="30">
         </operator>
         <connect from_op="Read Excel (3)" from_port="output" to_op="Cartesian" to_port="left"/>
         <connect from_op="Read Excel (2)" from_port="output" to_op="Cartesian" to_port="right"/>
         <connect from_op="Aggregate" from_port="example set output" to_op="Filter Examples (2)" to_port="example set input"/>
       </process>
     </operator>
    </process>
