"select by weight operator"
How can I provide input to the wei port of select by weight operator manually using an excel sheet.I tried the below format attribute weight
rlndc.opr.l_hub_centr 0.8829047139
frntl.inf.orb.r_hub_centr 0.8750850468
spp.mtr.ar.l_hub_centr 0.8646401198
frntl.md.r_hub_centr 0.8620028802
cdt.r_hub_centr 0.8334183679
frntl.inf.tr.l_hub_centr 0.8289782694
rlndc.opr.r_hub_centr 0.8274914408
I am getting the error"expected attribute but received example set"
1 - 1 of
11
http://stackoverflow.com/questions/25751350/machine-learning-in-rapidminerselect-by-weights-operator/25753101#25753101
Perhaps you could up-vote it if it's helpful
regards
Andrew
