"Issue in getting the predicted label from a Java application"
Hi,
I created a classification process using Rapidminer, now I'm trying to get the predicted label from this process in my JAVA application, for that I am using the following code:
I am using the same files and data in both sides.
Thanks for any help.
RapidMiner.setExecutionMode(RapidMiner.ExecutionMode.COMMAND_LINE);The problem is that the predicted label that I receive in my application is different from the predicted label from the rapidminer.
RapidMiner.init();
com.rapidminer.Process process = new com.rapidminer.Process(new File("readModel.rmp"));
IOContainer results = process.run();
results.asList();
ExampleSet resultSet2 = results.get(ExampleSet.class);
for (Example example : resultSet2) {
Attribute predictedLabel = example.getAttributes().getPredictedLabel();
predictionLabel = Double.parseDouble(example.getNominalValue(predictedLabel));
System.out.println(predictionLabel);
