Altair RISE
Nominate Yourself Now!
Error id: 475 ERROR SURFACE BUILD FROM SOLIDS PART
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi guys,
This error appears when I run a simulation of the impact RADIOSS. I am sending herewith the .out file
Could anyone help me?
Thank you
** ERROR SURFACE BUILD FROM SOLIDS PART
NON AVAILABLE OPTION /SURF/PART/Surf_ID FOR CREATING SURFACE 6
FROM A PART OF SOLIDS ;
USE /SURF/PART/EXT/Surf_ID or /SURF/PART/ALL/Surf_ID
<?xml version="1.0" encoding="UTF-8"?>post-33574-0-60667500-1415117671_thumb.p
1 - 6 of 61
    Altair Employee
    OP
    Hi felipeds
    One way is to create a SURF_EXT set instead of SURF in entity sets
    the other way is, open the starter file <filename>.0000.rad with a text pad andLook for a surface with this label,
    /SURF/PART/6
    and change to
    /SURF/PART/EXT/6
    Altair Employee
    OP
    Thank you Prakash Pagadala
    I made the second path that you indicated and it worked.
    Altair Employee
    OP
    Thank you for the update image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
    Altair Employee
    OP
    Hi! Could you tell me what the meaning is of that substitution and why? I don't understant what the error is. Thank you.
    Altair Employee
    OP
    Hi Mirino,
    could you brief about the error you have?
    Please the below commend from help when using SURF/PART for 3D elements:
    All surface segments must belong to 2D elements (shell element or a triangular shell element). 1D elements are ignored in /SURF/PART. With 3D elements user has to specify an additional keyword: see /SURF/PART/EXT and /SURF/PART/ALL
    Altair Employee
    OP
    Hi. I had the same error of felipeds. In the interface panel I would select as master a component which was solid (not shell). Since master wants only surface, I fixed the problem in this way: first of all, inside the panel 'entity set' I selected the component using as card image SURF_EXT; then, inside the panel 'interface,' I chose as master the set I previously created. And it worked. Is this procedure correct?
