Cube Root and Cube
Hi,
When trying to generate attributes, I know how to use the built-in functions for log transforms, etc. However, i do not know how to generate the cube root of a variable. Similarly, i also want to know how to generate the cube of a variable. Can someone please help me with these transformations?
Thanks,
James
Thanks,
James
Within the Generate Attributes operator you can use the function pow() - so for an attribute called att1, the cube would be pow(att1,3) and the cube root would be pow(att1,1/3)
regards
Andrew
