🎉Community Raffle - Win $25
Join and Win
Scrollbar for label list
Sai91User: "Sai91"
Altair Community Member
Updated by Sai91
Hello Everyone.
I am trying to create a scrollbar for list of labels using HWTK gui. But I am unable to do connect the scrollbar to label list. Is there a way to do it. Please see I dont want to use listbox as I have combobox in my window also. Any help would be much appreciated. Thank you.
1 - 3 of 31
    tinhUser: "tinh"
    Updated by tinh
    Use text box you can embed any label, button, etc...
    Hwtk textbox is designed with auto-scrollbars, you don't need to connect them to textbox any more
    tinhUser: "tinh"
    Updated by tinh
    Example:
    set t .labelList.text
    #create a text as label list:
    hwtk::text .labelList
    #add labels
    for {set i 1} {$i<100} {incr i} {
         label $t.lbl$i -text Label$i
         $t window create end -window $t.lbl$i
    $t configure -state disabled
    #pack it into your frame
    pack .labelList -in .yourFrame
    Sai91User: "Sai91"
    OP
    Updated by Sai91
    Thank you very much for your quick response and I apologies in my delay in replying as I was caught up with something else. Can I embed  combobox in textbox? I will try it. But I did manage to figure out a solution for my problem by embedding list of combobox(s) in a canvas and attaching scrollbar to it. If I can do it in hwtk text box then it would reduce my code length.
    Thanks again for your reply.
