Question about chose contact model
Raheem Sterling_22160
Raheem Sterling_22160 Altair Community Member
edited December 2022 in Community Q&A
Hi,
Now I have two types of particles like particleA and particleB, the contact model between particleA-particleA is Edinburgh elasto-plastic adhesion model, but for particleA-particleB and particleB-particleB I want to add an API by myself with no based model, but in the setting of  Edinburgh elasto-plastic adhesion model, if I don't add the parameters between particleA-particleB or particleB-particleB, EDEM cannot run with error of missing parameters.
Can I solve this problem?
I tried to solve it by setting the parameters in Edinburgh elasto-plastic adhesion model as 0, but it was still different with no base model.
Regards!
Raheem
Answers
  • Stephen Cole
    Stephen Cole
    Altair Employee
    Hi Raheem,
    There are a couple of options, in one case you would have to customise the EEPA model using the API to tell it to ignore specific combinations, to do this you would need the source code for the model in which case it's best to contact the author - https://www.eng.ed.ac.uk/about/people/dr-john-morrissey
    Otherwise you can chain contact models (so long as you are using the latest version of the API).  If the EEPA model is set to run first you can input any parameters for particleA-particleB and particleB-particleB and then the EEPA model will pass down the forces it calculates for this combination.  You can then just overwrite the calculated forces and add your own.
    contactResults.normalForce = MyValue;
    The above would overwrite normal force calculated so long as your model was second in the chain.  Using += would add to any previously calculated forces.
    Regards
    Stephen
  • Raheem Sterling_22160
    Hi Raheem,
    Regards
    Stephen
    Hi,
    Thanks, I would try to chain contact models, now I am using the EDEM2021, will it work for this version if I change the order? Or only works at the EDEM2022?
    Reagrd!
    Raheem
Welcome!
Welcome!
