🎉Community Raffle - Win $25
Join and Win
"[SOLVED] Filter examples node, how to attribute op attribute ?"
User: "mafern76"
New Altair Community Member
Updated by Jocelyn
Help states "attribute op value" is how the node works, I've been trying to see if there's a way to call again another attribute, but I can't find it.
For example: attribute1 = attribute2.
I'm guessing there must be some sort of escape character for marking "attribute2" as an attribute call, but I don't know it.
Thanks in advance!
1 - 3 of 31
    User: "Marco_Boeck"
    Hi,
    that is not supported out of the box. You will need to utilize the "Generate Attribute" operator for that, create a new flag attribute with an expression like "attribute1==attribute2" and then filter on that flag attribute (which you can remove afterwards).
    Regards,
    Marco
    User: "MariusHelf"
    This is not entirely true, Marco is too modest. :)
    He himself implemented the desired feature, it is available out of the box in the Filter Examples operator in RapidMiner 6.
    Best regards,
    Marius
    User: "mafern76"
    OP
    Thanks!!
    Best regards.
