Check and Fix Boundary Shell Intersections in HM 2019
Hi everyone,
I have just used HM 2019 version and see a new feature (Check 2D Mesh) in tetramesh panel.
I have read Altair's Help but I can't apply this feature to my model. When I clicked the fix button, the intersection elements are deleted.
Has anyone used this feature yet? How do I use this feature properly?
The attachments below are my model file.
Thanks in advance.
Thank @Q.Nguyen-Dai.
This link below contains the HM 2019 slide.
http://blog.altair.co.kr/wp-content/uploads/2019/05/HyperMesh-2019-Updates-3D-modeling-_Fuse.pdf
I keep the red lines because I want to create the same model as on the slide (page 12). I want to try new feature (Check 2D Mesh in tetramesh panel).
Have you used that feature yet? Does it work correctly?
Thank @Rahul R very much. To use this feature, mesh should be enclose. It works pretty well.
Thank again.
Dear @Khac Thanh, i tried to use this feature to repair Boundary Shell, but it didn't change at all. Then, I creat a very simple model, i.e., a cube, and manually creat a intersection shown as below. The situation is same, the mesh was not modified even though I did fix.
Could you show me how to use this function correctly? Thanks a lot!
IMHO you have to fix your surfaces firstly, before making your mesh by doing equivalence of edges. You have to have all green edges.
Geom => edge edit => equivalence
