Check and Fix Boundary Shell Intersections in HM 2019
User: "Khac Thanh"
Altair Community Member
Updated by Khac Thanh
Hi everyone,
I have just used HM 2019 version and see a new feature (Check 2D Mesh) in tetramesh panel.
<?xml version="1.0" encoding="UTF-8"?>image.thumb.png.3e99c80d9dc6b468214a113134f3903e.png
<?xml version="1.0" encoding="UTF-8"?>image.thumb.png.91309c15192a75d8dde1d295be25008b.png
I have read Altair's Help but I can't apply this feature to my model. When I clicked the fix button, the intersection elements are deleted.
<?xml version="1.0" encoding="UTF-8"?>image.thumb.png.113fd1888e3d41abb84210331ff83f0b.png
<?xml version="1.0" encoding="UTF-8"?>image.thumb.png.97d111c1449fa39684ff01cd52947f07.png
Has anyone used this feature yet? How do I use this feature properly?
The attachments below are my model file.
Thanks in advance.
1 - 5 of 51
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    IMHO you have to fix your surfaces firstly, before making your mesh by doing equivalence of edges. You have to have all green edges.
    Geom => edge edit => equivalence
    User: "Khac Thanh"
    OP
    Thank @Q.Nguyen-Dai.
    This link below contains the HM 2019 slide.
    http://blog.altair.co.kr/wp-content/uploads/2019/05/HyperMesh-2019-Updates-3D-modeling-_Fuse.pdf
    I keep the red lines because I want to create the same model as on the slide (page 12). I want to try new feature (Check 2D Mesh in tetramesh panel).
    Have you used that feature yet? Does it work correctly?
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    To try this feature mesh should be enclose and element failing in aspect(sliver).
    User: "Khac Thanh"
    OP
    Thank @Rahul R very much. To use this feature, mesh should be enclose. It works pretty well.
    Thank again.
    User: "Hui Liu"
    Updated by Hui Liu
    Dear @Khac Thanh, i tried to use this feature to repair Boundary Shell, but it didn't change at all. Then, I creat a very simple model, i.e., a cube, and manually creat a intersection shown as below. The situation is same, the mesh was not modified even though I did fix.
    Could you show me how to use this function correctly? Thanks a lot!
