1 - 6 of
61
Apr 03, 2014 3:21:34 PM com.rapidminer.tools.I18N <clinit>
INFO: Set locale to en.
Apr 03, 2014 3:21:35 PM com.rapidminer.tools.plugin.Plugin registerPlugins
WARNING: The jar file .\lib\plugins\gentlyWEB.jar does not contain an entry RapidMiner-Type in its manifest and will therefore not be loaded (if this file actually is a plugin updating the plugin file might help).
WARNING: The jar file .\lib\plugins\JoSQL-1.8.jar does not contain an entry RapidMiner-Type in its manifest and will therefore not be loaded (if this file actually is a plugin updating the plugin file might help).
WARNING: The jar file .\lib\plugins\maxmindgeoip-1.2.0.jar does not contain an entry RapidMiner-Type in its manifest and will therefore not be loaded (if this file actually is a plugin updating the plugin file might help).
WARNING: The jar file .\lib\plugins\polliwog.jar does not contain an entry RapidMiner-Type in its manifest and will therefore not be loaded (if this file actually is a plugin updating the plugin file might help).
WARNING: Duplicate plugin definition for plugin rmx_web in .\lib\plugins\rapidminer-Web Mining-5.3.001.jar and .\lib\plugins\rapidminer-Web Mining-5.3.000.jar. Keeping the one with the higher version number.
WARNING: The jar file .\lib\plugins\rome.jar does not contain an entry RapidMiner-Type in its manifest and will therefore not be loaded (if this file actually is a plugin updating the plugin file might help).
WARNING: The jar file .\lib\plugins\websphinx.jar does not contain an entry RapidMiner-Type in its manifest and will therefore not be loaded (if this file actually is a plugin updating the plugin file might help).
INFO: Register plugin: Information-Extraction
INFO: Register plugin: Text Processing
INFO: Register plugin: Web Mining
WARNING: Duplicate plugin definition for plugin rmx_text in .\lib\plugins\rapidminer-Text Processing-5.1.001.jar and C:\Users\HammadAlam\.RapidMiner5\managed\rmx_text-5.3.2.jar. Keeping the first.
WARNING: Duplicate plugin definition for plugin rmx_web in .\lib\plugins\rapidminer-Web Mining-5.3.001.jar and C:\Users\HammadAlam\.RapidMiner5\managed\rmx_web-5.3.1.jar. Keeping the first.
Apr 03, 2014 3:21:35 PM com.rapidminer.tools.plugin.Plugin registerAllPluginDescriptions
WARNING: Cannot register operators from Web Mining: Dependencies not fulfilled! This plugin needs a RapidMiner version 5.2 and the following plugins:
[rmx_text (5.2)]
Apr 03, 2014 3:21:36 PM com.rapidminer.tools.expression.parser.ExpressionParserFactory <clinit>
INFO: Default version of expression parser registered successfully
Apr 03, 2014 3:21:37 PM com.rapidminer.parameter.ParameterTypePassword decryptPassword
WARNING: Password in XML file looks like unencrypted plain text.
Apr 03, 2014 3:21:38 PM com.rapidminer.tools.OperatorService init
INFO: Loading additional operators specified by rapidminer.operators.additional (${RAPIDMINER_OPERATORS_ADDITIONAL})
SEVERE: Cannot find operator description file ${RAPIDMINER_OPERATORS_ADDITIONAL}.
[rmx_text (5.2)]
Hi,
the problem is that you have installed the text extension twice. This confuses RapidMiner and sadly in this version it then takes the old (wrong) version. Then the web extension complains that the reequired minimum text extension version is not available and thus the web operators are not available.
Please get rid of the .\lib\plugins\rapidminer-Text Processing-5.1.001.jar.
See the following warning from the log:
Regards,
Marco
The second one is the one you need.
Regards,
Marco
when you select "Help" -> "Manage extensions..." in the top menu, what does it say for Text and Web extension?
What version of RapidMiner Studio are you using?
What does the log file say? It can be found in userhome/.RapidMiner/rapidminer-studio.log for RM Studio 6 or in userhome/.RapidMiner5/rm.log for RM 5.
Regards,
Marco
