Particle Orientation matrix
User: "Saeed Naamnh"
Altair Community Member
Updated by Saeed Naamnh
1 - 10 of 101
    User: "RWood"
    Altair Employee
    Accepted Answer
    Updated by RWood
    Hi,
    Internally everything is done using quaternions but the user should only see the 3x3 rotation matrix representation. It's pretty trivial to convert between the two, should you need to.
    https://en.m.wikipedia.org/wiki/Quaternions_and_spatial_rotation
    Richard
    OP
    Thanks Richard
    OP
    Hi
    Do you know why the matrix is not symmetric ?
    And why the some of the diagonal values are minus (-)
    User: "RWood"
    Altair Employee
    Updated by RWood
    Hi
    Replied in your other post
    https://community.altair.com/community?id=community_Question&sys_id=35270f5a1b8955d0507ca6442a4bcbf3
    User: "Stephen Cole"
    Altair Employee
    Updated by Stephen Cole
    Hi
    Hi,
    With regard to the -ve values this is a useful link for visualising the different orientations:
    http://www.euclideanspace.com/maths/algebra/matrix/transforms/examples/index.htm
    This would be the matrix to rotate a particle from the position in the Creator at 45degrees in Y axis for example:
    If I do 10 degrees in X, 20 in Y and 30 in Z we get:
    I use the attached spreadsheet to help with regard to helping understand the different orientations.
    OP
    Hi Stephen
    Thank you for the clarification, But how can I determine the angle value from edem ?
    User: "Salma Hassan"
    Updated by Salma Hassan
    Hi Stephen,
    I want to predicate the intra-particle coating uniformity as a function of the particle's orientation as they pass through the spray zone, and am simulating a spherical shape. From the orientation matrix, how can I determine which vector is the direction of the particle's face?
    particle 1
    type: Urea
    velocity: x = 0.621758 m/s, y = -0.263098 m/s, z = -0.00719657 m/s
    position: x = -100.179 mm, y = -99.7823 mm, z = 26.0024 mm
    angular velocity: x = 76.4974 rad/s, y = -38.4065 rad/s, z = 46.7943 rad/s
    force: x = -1.22761e-05 N, y = -7.95452e-05 N, z = 0.000232114 N
    total force: 0.000245672 N
    compressive force: 0.000225682 N
    torque: x = 5.3362e-07 Nm, y = -2.50706e-07 Nm, z = 4.16641e-07 Nm
    mass: 4.46103e-05 kg
    residence time: 60 s
    orientation
    x: x = -0.490355, y = -0.448063, z = -0.747524
    y: x = 0.753977, y = 0.212096, z = -0.621718
    z: x = 0.437116, y = -0.868478, z = 0.233827
    Custom Properties
    Liquid Volume: 9.38404e-11 m³
    Custom Residence Time: 0.768615 s
    User: "Raïsa Roeplal"
    Updated by Raïsa Roeplal
    Hi,
    Hi Stephen,
    I am trying to create a cubic particle which has a fixed orientation. The cube should be rotated 45 degrees about the y-axis, so I used the orientation matrix you presented above. However, EDEM then gives the following message:
    Why is this a problem?
    Altair Employee
    Hi Stephen,
    Hi Raisa,
    Do the particles still get created?  This is a warning typically generated due to the accuracy of the inputs but can still allow the particle to be created.
    You could try adding the values at a different precision to check if this is accepted by the matrix.  Just to note this error checking has been improved in EDEM 2022.3, it allows inputs to greater accuracy and only checks if it's orthogonal to 3 decimal places.
    2022.3 should be released this week so it maybe best to check with that version once uploaded to the community site.
    Regards
    Stephen
    Hi Raisa,
    Regards
    Stephen
    Thanks for your reply Stephen! Unfortunately EDEM 2022.2 does not allow me to increase the accuracy beyond 3 decimal places. I will try this in version 2022.3!
