How to calculate Moments and maximum force from a section taken in hypermesh. I have thickness and material data with me.
Hi Prakash,
I want to calculate at pre-processing stage. Is there any possibility?
Hi Prakash,
Yes, it's possible with .... 'Strength of Materials' course!
Please, understand my requirement.
I have nodes, material and thickness. Now, from hypermesh can i calculate section force and thickness at preprocessing stage??
Hi @Jouher
Not sure what you mean by at PREPROCESSING stage means, but FBD is also used to extract cross-sectional resultant forces and moments (typically at the centroid of a cross-section) for use in traditional strength calculations.
Hello @Jouher,
Greetings!!
When you say preprocessing stage, do you mean applying a pre-load to a component/part?
If that's the case, you might want to look into the topic of explicit dynamic relaxation.
http://ftp.lstc.com/anonymous/outgoing/jday/bolt_preload3.pdf
If you are using LS-Dyna, you can have created a output file, wherein you can extract the data before the actual simulation begins (i.e during pre-load period).
You can find something similar for RADIOSS I believe. (>DYREL option)
Please, let us know, if you find a proper solution.
Hi,
You can use Free body diagram module to calculate shear force and bending moment. Please refer to OptiStruct help for more details on the same.
