NonLinear Forecast/Prediction
Hej guys,
I HAVE A QUESTION ::)
I`m currently working on a pricing-issue where I want to forecast the price-decrease of several products.
THE PROBLEM: The historical data points out that the price decreased non-linear so far. Instead it decreases quite strong at the beginning but the longer the product is on the market the more the price approaches a zero decline. I`m pretty much a beginner with Rapidminer and could only figure out that linear regression would not help me to forecast scoring-datasets in a meaningful manner.
WHAT TO DO?
Can you help me with that?
br
WHAT TO DO?
br
1 - 3 of
31
Hi,
if you know that the descent is logarithmic you can try to transform the data before applying a Linear Regression with the Generate Attributes operator, e.g. by taking exp(price).
In the general case you can use one of the various non-linear regression algorithms like SVM with radial kernel or Gaussian Process.
Best regards,
Marius
Best regards,
Marius
Hej Marius,
BIG THANKS for your response. I haven´t expected anyone answering anymore and unfortunately I didnt get any message that I fortunately got a response. Anyways, I tried the SVM as well as Neural Networks and it works good for my purpose. I would like to understand your advice to use the exp(price) function for applying linear regression. It seems that it almost straightens the price function except for the first point (300€) but how do I proceed from their? How should I transform the testing/scoring set to apply the regression and get a reasonable forecast?
Furthermore I was wondering how I can arrange the algorithm to measure seperate values according to the ID. I have product A, product B and product C in my dataset and each has different prices and accordingly different price curves. I indicate the product name as ID but when I run the SVM it can´t distinguish between the different products and gives just a mutual value for each product as if they were al the same. What am I doing wrong in this case?
Cheers
Cheers
Probably I also explained the problem not got enough.
The price decreases over time as follows (just an example):
01.01.2012 - 350€
01.03.2012 - 300€
01.06.2012 - 270€
01.09.2012 - 245€
01.12.2012 - 227€
01.03.2013 - 215€
01.06.2013 - 205€
01.09.2013 - 197€
01.12.2013 - 191€
What I need to do is a prediction for the upcoming months. It seems like a logarithmic trend but I dont know how to build such a process effectively.
Thanks for any advice or sharing of your thoughts.
