🎉Community Raffle - Win $25
Join and Win
"Text Processing plugin in Java App"
User: "rane"
New Altair Community Member
Updated by Jocelyn
I made a Java application that classifies the data inside an excel file. Here's a snippet of the code.
            RapidMiner.setExecutionMode(RapidMiner.ExecutionMode.COMMAND_LINE);
            ProcessEntry pEntry = null;
            RepositoryManager.getInstance(null).addRepository(new LocalRepository("RMThesis", new File("Resources/TrendClass(70%)")));
            if(cbAlgo.getSelectedItem() == "k-NN"){
                RepositoryLocation location = new RepositoryLocation("//RMThesis/Apply Model (Oct Data)");
                pEntry = (ProcessEntry) location.locateEntry();
                RapidMiner.init();
                JOptionPane.showMessageDialog(null, "Location set", "Message", JOptionPane.INFORMATION_MESSAGE);
            else if(cbAlgo.getSelectedItem() == "SVM"){
                RepositoryLocation location = new RepositoryLocation("//RMThesis/Apply Model (SVM)");
                RapidMiner.init();
            else if(cbAlgo.getSelectedItem() == "Naive Bayes"){
                RepositoryLocation location = new RepositoryLocation("//RMThesis/Apply Model (NB)");
                RapidMiner.init();
          if(pEntry instanceof ProcessEntry)
                String processXML = pEntry.retrieveXML();
                Process myProcess = new Process(processXML);
                Operator op = myProcess.getOperator("Read Excel");
                op.setParameter(ExcelExampleSource.PARAMETER_EXCEL_FILE, selectedFile.getPath());
                IOContainer ioResult = myProcess.run();
I already added the rmx_text-ANY-5.3.2.jar in my library to be able to use text processing but still i have this error. I hope someone can help me :(
Feb 22, 2014 8:45:04 PM com.rapidminer.tools.ParameterService init
INFO: Reading configuration resource com/rapidminer/resources/rapidminerrc.
Feb 22, 2014 8:45:04 PM com.rapidminer.tools.I18N <clinit>
INFO: Set locale to en.
Feb 22, 2014 8:45:04 PM com.rapid_i.Launcher ensureRapidMinerHomeSet
INFO: Property rapidminer.home is not set. Guessing.
INFO: Trying parent directory of 'C:\Users\jeraymundo\Desktop\Prototype NEW\Prototype\Resources\launcher.jar'...gotcha!
INFO: Trying parent directory of 'C:\Users\jeraymundo\Desktop\Prototype NEW\Prototype\Resources\rapidminer.jar'...gotcha!
Feb 22, 2014 8:45:05 PM com.rapidminer.tools.expression.parser.ExpressionParserFactory <clinit>
INFO: Default version of expression parser registered successfully
Feb 22, 2014 8:45:06 PM com.rapidminer.parameter.ParameterTypePassword decryptPassword
WARNING: Password in XML file looks like unencrypted plain text.
Feb 22, 2014 8:45:07 PM com.rapidminer.tools.OperatorService init
INFO: Number of registered operator classes: 443; number of registered operator descriptions: 444; number of replacements: 403
Feb 22, 2014 8:45:07 PM com.rapidminer.tools.jdbc.JDBCProperties registerDrivers
INFO: JDBC driver com.mysql.jdbc.Driver not found. Probably the driver is not installed.
INFO: JDBC driver org.postgresql.Driver not found. Probably the driver is not installed.
INFO: JDBC driver net.sourceforge.jtds.jdbc.Driver not found. Probably the driver is not installed.
INFO: JDBC driver org.hsqldb.jdbcDriver not found. Probably the driver is not installed.
Feb 22, 2014 8:45:07 PM com.rapidminer.tools.jdbc.JDBCProperties <init>
WARNING: Missing database driver class name for ODBC Bridge (e.g. Access)
INFO: JDBC driver com.ingres.jdbc.IngresDriver not found. Probably the driver is not installed.
INFO: JDBC driver ca.ingres.jdbc.IngresDriver not found. Probably the driver is not installed.
INFO: JDBC driver oracle.jdbc.driver.OracleDriver not found. Probably the driver is not installed.
Feb 22, 2014 8:45:08 PM com.rapidminer.io.process.XMLImporter addMessage
INFO: <em class="error">The operator class 'text:data_to_documents' is unknown. Possibly you must install a plugin for operators of group 'text'.</em>
Feb 22, 2014 8:45:08 PM com.rapidminer.io.process.XMLImporter parseOperator
INFO: The parameter 'select_attributes_and_weights' is unknown for operator 'Data to Documents (2)' (" dummy ")."
INFO: The parameter 'specify_weights' of type list is unknown for operator 'Data to Documents (2)' (" dummy ")."
INFO: <em class="error">The operator class 'text:process_documents' is unknown. Possibly you must install a plugin for operators of group 'text'.</em>
INFO: The parameter 'create_word_vector' is unknown for operator 'Process Documents' (" dummy ")."
INFO: The parameter 'vector_creation' is unknown for operator 'Process Documents' (" dummy ")."
INFO: The parameter 'add_meta_information' is unknown for operator 'Process Documents' (" dummy ")."
INFO: The parameter 'keep_text' is unknown for operator 'Process Documents' (" dummy ")."
INFO: The parameter 'prune_method' is unknown for operator 'Process Documents' (" dummy ")."
INFO: The parameter 'prune_below_percent' is unknown for operator 'Process Documents' (" dummy ")."
INFO: The parameter 'prune_above_percent' is unknown for operator 'Process Documents' (" dummy ")."
INFO: The parameter 'prune_below_rank' is unknown for operator 'Process Documents' (" dummy ")."
INFO: The parameter 'prune_above_rank' is unknown for operator 'Process Documents' (" dummy ")."
INFO: The parameter 'datamanagement' is unknown for operator 'Process Documents' (" dummy ")."
INFO: <em class="error">Operator '<class>dummy</class>' may not have children. Ignoring.
INFO: <em class="error">The input port <var>example set</var> is unknown at operator <var>Data to Documents (2)</var>.</em>
INFO: <em class="error">The input port <var>word list</var> is unknown at operator <var>Process Documents</var>.</em>
INFO: <em class="error">The output port <var>documents</var> is unknown at operator <var>Data to Documents (2)</var>.</em>
INFO: <em class="error">The output port <var>example set</var> is unknown at operator <var>Process Documents</var>.</em>
Feb 22, 2014 8:45:15 PM com.rapidminer.tools.WrapperLoggingHandler log
INFO: No filename given for result file, using stdout for logging results!
Feb 22, 2014 8:45:15 PM com.rapidminer.Process run
INFO: Process starts
com.rapidminer.operator.UserError: The dummy operator Data to Documents (2) (replacing text:data_to_documents) cannot be executed.
at com.rapidminer.operator.DummyOperator.doWork(DummyOperator.java:88)
at com.rapidminer.operator.Operator.execute(Operator.java:866)
at com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:51)
at com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:711)
at com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:375)
