Can't Run the motor models
User: "Albert_Dunford"
Altair Employee
Updated by Albert_Dunford
1 - 2 of 21
    Altair Employee
    OP
    Go to options->license setup
    And check the boxes
    Note, the unit draw of
    power supply is 10
    code gen 15
    co-simulation 15
    motor drive 20
    The max units you can draw is 20.
    Altair Employee
    OP
    This article also applies if you need to Activate the motor drive library of PSIM or you get other error messages about motor models not working in PSIM
