RapidMiner Studio 6 on Mac OS X
UPDATE, 6th of May, 2015:
RapidMiner Studio 6.4 now comes with a dedicated OS X version which ships with its own .dmg installer. It behaves much like a native OS X application and should alleviate previous starting problems on Mac.
This post is directed at users that struggle with running RapidMiner Studio 6 on Mac OS X. In particular, the problem that RapidMiner Studio 6 does not start despite having installed Java 7 is addressed.
Some Background
There is no Java Runtime Environment shipped with the platform independent release of RapidMiner Studio. Instead the default Java installation of the operating system is used. RapidMiner Studio 6 requires Java 7 or newer. However, Apple only ships a Java 6 release along with its operating system. This means that you have to install a Java 7 release manually. You can download Java 7 at:
http://www.oracle.com/technetwork/java/javase/downloads/index.html.
Problem Description
Unfortunately, this still does not solve the startup problems for some users. In some cases RapidMiner Studio is unable to find this new installation, tries to use the old one instead, and thus fails to start showing a warning that the Java installation is outdated.
Solutions
We hope to solve this problem with the upcoming update of RapidMiner Studio. Until then, you can try one of the following two approaches:
Install a Java 7 Development Kit (JDK)
In most cases installing the Java Development Kit (JDK) instead of the Java Runtime Environment (JRE) solves the problem. However, the JDK requires additional disk space. Another option is to use a preview release of the new Mac OS X Launcher of RapidMiner Studio.
Use the Preview Release of the New Mac OS X Launcher
You can download preview release of the new Mac OS X Launcher here:
RapidMiner Studio version 6 up to 6.0.008
RapidMiner Studio version 6.1
This launcher should be able to detect Java 7 installations even if they are not the system default. To use this launcher, extract the archive and copy the included files (“RapidMiner Studio (Preview).app” and RapidMiner-Studio-Preview.sh) to the root directory of your RapidMiner installation (the same directory that contains the old launcher named “RapidMiner Studio.app”). You should now be able to run RapidMiner Studio by double clicking on the new launcher (“RapidMiner Studio (Preview).app”). Please consider sending us some feedback concerning this new launcher!
Please Send Us Feedback (Preview Launcher)
You can help us identifying potential problems with the new launcher by sending use the following information (e.g., via PM or reply to this thread):
Some Background
Problem Description
Solutions
- The contents of the log "OSX-Startup.log". This file will be created in the directory containing (“RapidMiner Studio (Preview).app”) when you use the new launcher.
- The version of Mac OS X you are running (click on the Apple Symbol in the menu bar and open "About This Mac").
- Your default Java installation (open Terminal and run "java -version")
- Your default Java 7 installation (open Terminal and run "/usr/libexec/java_home -v 1.7")
- You JRE installation (if any) (open Terminal and run "/Library/Internet\ Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java -version")
1 - 6 of
61
I am having the same issue. I tried using 'java -Xmx1024M -jar rapidminer.jar' in Terminal from lib folder but get the following and no launch:
Exception in thread "main" java.lang.UnsupportedClassVersionError: com/rapidminer/gui/RapidMinerGUI : Unsupported major.minor version 51.0
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClassCond(ClassLoader.java:637)
at java.lang.ClassLoader.defineClass(ClassLoader.java:621)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:141)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:283)
at java.net.URLClassLoader.access$000(URLClassLoader.java:58)
at java.net.URLClassLoader$1.run(URLClassLoader.java:197)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
Peters-iMac:lib pedro$ run java -Xmx1024M -jar rapidminer.jar
-bash: run: command not found
Peters-iMac:lib pedro$ java -Xmx1024M -jar rapidminer.jar
How can I get RapidMiner to launch?
Thanks.
Pedro
Thanks.
Pedro
I installed the java jdk package from here--http://www.oracle.com/technetwork/java/javase/downloads/jdk7-downloads-1880260.html-- and it now launches properly.
Pedro
Pedro
I have the same problem as Aegean does: fail to launch Rapid Miner Studio. app 6.2.0 on mac osx yosemite version 10.10.2 with java 8 installed, and gott the following error message:
Starting RapidMiner Studio failed!
Reason: RapidMiner Studio requires Java 1.7 or newer. Found Java 1.6.
Is there a fix coming? And it seems this issue also surface one year ago, on OS X 10.9.
Thanks
Thanks
- java version "1.8.0_20"
When launching RapidMiner, I get the following error message:Java(TM) SE Runtime Environment (build 1.8.0_20-b26)
Java HotSpot(TM) 64-Bit Server VM (build 25.20-b23, mixed mode)
"The maximum memory setting of '3.641' MB is not valid for your current license. Please make sure that the RapidMinder Studio launch script is not manipulated and restart RapidMiner Studio."
How do I make sure the RapidMinder launch script hasn't been manipulated and more generally, what do I need to do to configure RapidMiner to launch successfully?
Thank you.
