"Recursive partitioning regression tree?"
tmanasa
tmanasa New Altair Community Member
edited November 2024 in Community Q&A
I would like to discover explanatory variables for a numeric dependent variable (which conditions result in the shortest commute times on any given week day). Some of the explanatory variables are numeric, others are categoric. Does RapidMiner have any algorithms that can handle that?
I understand that recursive partitioning regression trees can. Is there an equivalent or alternative in RM?
Answers
  • MariusHelf
    MariusHelf New Altair Community Member
    Hi Ted,
    RapidMiner's Decision Trees can only be used for classification problems, not for regression tasks. But they can deal with both nominal an numeric explanatory attributes.
    If you want to stick to decision trees you can discretize the label (as we call the dependent variable) with one of the Discretize operators.
    However, decision trees are probably not the best way to define the explanatory power of variables. For that you could e.g. try the Linear Regression and have a look at p-value and attribute weights of the resulting model, or use a Forward Selection around a decision tree.
    Best regards,
    Marius
  • RalfKlinkenberg
    RalfKlinkenberg New Altair Community Member
    Hi Ted,
    if you install the Weka Extension for RapidMiner, you can use regression tree learners from Weka seamlessly within RapidMiner:
    <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    <process version="6.0.001">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="6.0.001" expanded="true" name="Process">
        <process expanded="true">
          <operator activated="true" class="generate_data" compatibility="6.0.001" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30">
            <parameter key="target_function" value="polynomial"/>
            <parameter key="number_of_attributes" value="3"/>
            <parameter key="attributes_lower_bound" value="0.0"/>
          </operator>
          <operator activated="true" class="multiply" compatibility="6.0.001" expanded="true" height="94" name="Multiply" width="90" x="45" y="120"/>
          <operator activated="true" class="weka:W-M5P" compatibility="5.3.001" expanded="true" height="76" name="W-M5P" width="90" x="179" y="120"/>
          <operator activated="true" class="weka:W-REPTree" compatibility="5.3.001" expanded="true" height="76" name="W-REPTree" width="90" x="179" y="30"/>
          <connect from_op="Generate Data" from_port="output" to_op="Multiply" to_port="input"/>
          <connect from_op="Multiply" from_port="output 1" to_op="W-REPTree" to_port="training set"/>
          <connect from_op="Multiply" from_port="output 2" to_op="W-M5P" to_port="training set"/>
          <connect from_op="W-M5P" from_port="model" to_port="result 3"/>
          <connect from_op="W-REPTree" from_port="model" to_port="result 1"/>
          <connect from_op="W-REPTree" from_port="exampleSet" to_port="result 2"/>
          <portSpacing port="sink_result 3" spacing="0"/>
          <portSpacing port="sink_result 4" spacing="0"/>
        </process>
      </operator>
    </process>
    For installing the Weka Extension, start RapidMiner, go to the Help menu, and then to the "Updates and Extensions (Marketplace)" submenu.
    Cheers,
    Ralf
Welcome!
Welcome!
