Generate new multiple attributes!!!
User: "Shiwaani"
New Altair Community Member
Updated by Jocelyn
There are 3 attributes namely ID LISTINGS CURRENTVALUE...I need to report for every record, LISTINGS which lies between 0.8 and 1.8 of the CURRENTVALUE.
I would hope to generate a new attribute to hold each LISTING whose value lies in the following range(0.8 to 1.8 of the CurrentValue).
Thx
1 - 6 of 61
    User: "sgenzer"
    Altair Employee
    Hello yes generate attribute operator is correct. The expression should be something like:
    if(CURRENTVALUE>0.8&&CURRENTVALUE<1.8,LISTINGS,"")
    Scott
    User: "Shiwaani"
    OP
    Thank you Scott for the reply,but I require the system to loop through the CurrentValue (for each record) and provide me with an array of Listings.
    -Shiwaani
    User: "sgenzer"
    Altair Employee
    Can you show me a piece of your example set?
    User: "Shiwaani"
    OP
    Dataset
    ID  Listing  Current Value
    11A  ABC        600
    12A  DEF        400
    13A  GHI        800
    14A  JKL        200
    15A  MNO    1200
                          Range
    .8*CurrentValue  1.8*CurrentValue
    480                            1080
    320                            720
    640                            1440
    160                            360
    960                            2160
    Desired output
    ID        Listing          Current Value  NewVar1      NewVar2    NewVar3
    11A      ABC            600                    ABC              GHI
    12A      DEF            400                    DEF            ABC
    13A      GHI            800                      GHI              MNO
    14A    JKL            200                    JKL
    15A    MNO          1200                  MNO
    User: "sgenzer"
    Altair Employee
    ok I don't think this is the most elegant solution (and the results are transposed from what you want) but here you go:
    <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    <process version="6.5.002">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="6.5.002" expanded="true" name="Process">
        <process expanded="true">
          <operator activated="true" class="retrieve" compatibility="6.5.002" expanded="true" height="60" name="Retrieve FOO" width="90" x="45" y="75">
            <parameter key="repository_entry" value="//Local Repository/FOO"/>
          </operator>
          <operator activated="true" class="remember" compatibility="6.5.002" expanded="true" height="60" name="Remember" width="90" x="179" y="75">
            <parameter key="name" value="exampleset"/>
          </operator>
          <operator activated="true" class="loop_examples" compatibility="6.5.002" expanded="true" height="76" name="Loop Examples" width="90" x="313" y="75">
              <operator activated="true" class="extract_macro" compatibility="6.5.002" expanded="true" height="60" name="Extract Macro" width="90" x="45" y="30">
                <parameter key="macro" value="currentvalue"/>
                <parameter key="macro_type" value="data_value"/>
                <parameter key="attribute_name" value="Current Value"/>
                <parameter key="example_index" value="%{example}"/>
                <list key="additional_macros"/>
              </operator>
              <operator activated="true" class="generate_macro" compatibility="6.5.002" expanded="true" height="76" name="Generate Macro" width="90" x="179" y="30">
                <list key="function_descriptions">
                  <parameter key="lowerbound" value="eval(%{currentvalue})*0.8"/>
                  <parameter key="upperbound" value="eval(%{currentvalue})*1.8"/>
                </list>
              </operator>
              <operator activated="true" class="recall" compatibility="6.5.002" expanded="true" height="60" name="Recall" width="90" x="179" y="165">
                <parameter key="remove_from_store" value="false"/>
              </operator>
              <operator activated="true" class="generate_attributes" compatibility="6.5.002" expanded="true" height="76" name="Generate Attributes" width="90" x="313" y="165">
                  <parameter key="NewVar%{example}" value="if([Current Value]&gt;eval(%{lowerbound})&amp;&amp;[Current Value]&lt;eval(%{upperbound}),[Listing],&quot;&quot;)"/>
                </list>
              </operator>
              <operator activated="true" class="remember" compatibility="6.5.002" expanded="true" height="60" name="Remember (3)" width="90" x="447" y="165">
              </operator>
              <connect from_port="example set" to_op="Extract Macro" to_port="example set"/>
              <connect from_op="Extract Macro" from_port="example set" to_op="Generate Macro" to_port="through 1"/>
              <connect from_op="Recall" from_port="result" to_op="Generate Attributes" to_port="example set input"/>
              <connect from_op="Generate Attributes" from_port="example set output" to_op="Remember (3)" to_port="store"/>
              <portSpacing port="source_example set" spacing="0"/>
              <portSpacing port="sink_example set" spacing="0"/>
              <portSpacing port="sink_output 1" spacing="0"/>
            </process>
          </operator>
          <operator activated="true" class="recall" compatibility="6.5.002" expanded="true" height="60" name="Recall (3)" width="90" x="514" y="75">
          </operator>
          <connect from_op="Retrieve FOO" from_port="output" to_op="Remember" to_port="store"/>
          <connect from_op="Remember" from_port="stored" to_op="Loop Examples" to_port="example set"/>
          <connect from_op="Recall (3)" from_port="result" to_port="result 1"/>
        </process>
      </operator>
    </process>
    User: "Shiwaani"
    OP
    Thx Scott, I was hoping for a operator based response ,yet I will give this a try.
