Can't import CSV data on Mac
User: "Frydek"
New Altair Community Member
Updated by Jocelyn
Hi
I'm new here. I'm just getting started with RapidMiner.
I'm trying to import a csv file and clicking import csv doesn't do anything.
Am I missing something? I've followed tutorials and in them a wizard appears, which doesn't happen in my case.
The only three options that work are import access, database and binary.
1 - 18 of 181
    User: "Frydek"
    OP
    Well, I'm on 10.6.8 thus Java 6... Unresolvable as far as I know...
    Hi,
    I'm afraid if you do not have access to Java 7, you will either need to use RM 5.3.008, or update your OS to Mountain Lion (OS X 10.8) for the imports to work correctly.
    Regards,
    Marco
    User: "ldamiani"
    Im having the same problem on a mountain lion with Java 7 (v25)
    User: "Reshma"
    I'm on Mountain Lion and using RM 5.3.013. I have Java 7.
    I opened RM from inside the scripts folder by double clicking RapidMinerGUI.
    When the tool started the first time, I was not prompted for creating a new repository. I started a New Process and then created a new repository. If I try to import a .csv, I get nothing and there's not error messages either.
    Can someone help?!
    User: "Marco_Boeck"
    Altair Employee
    Hi,
    what does it say when you enter the following in your terminal?
    java -version
    Regards,
    Marco
    User: "Reshma"
    Hi March
    java version "1.6.0_43"
    Java(TM) SE Runtime Environment (build 1.6.0_43-b01-447-11M4203)
    Java HotSpot(TM) 64-Bit Server VM (build 20.14-b01-447, mixed mode)
    That's what  I see.
    Reshma
    User: "Marco_Boeck"
    Altair Employee
    Hi,
    so your Mac is not using Java 7 as the default JVM. Can you try the following:
    Go to your Java Preferences in the utilities, and change the order (drag) so Java 7 is at the top.
    Then run the terminal test again.
    Regards,
    Marco
    User: "Reshma"
    Thanks Marco
    The funny thing is that in my java preferences under Java Runtime Environment Settings, I only see 1.7. The Java Control Panel is available in my System Preference and that means my system is using Java 7 (I think) but when I run the command Java -version in my terminal, it still returns:
    I am at a complete loss on forcing my system to use Java 7.
    User: "mdchambers0"
    It turns out when I installed Java 7 it didn't get rid of Java 6.  I had to get rid of Java 6 then reinstall java 7 then the program worked fine.
    Hi
     I am running RM 5.3.013 and OSX 10.8.5 and this feature still does not work????  I can not import CSV files.
    Any ideas????
    Hi,
    what does echo $JAVA_HOME say when you enter it in the terminal?
    Regards,
    Marco
    User: "Reshma"
    Nothing is returned. It's blank.
    I suspect we need to set this in some type of profile?
    User: "Kozma"
    Hi,
    The same thing happened to me. Two things got it working:
    Open the Java Preferences Utility (Applications > Utilities) and move Java 7 to the top. [This is different from the System Preferences, which, as you've seen, doesn't do any good.]
    I did this before I figured out the Preferences, so don't know how much difference it made. I installed the Java Developer's Kit (JDK), I think from the advice of another post on here.
    Good luck!
    User: "paulalford"
    Well, following these steps has broken my RM installation.
    I proceeded with the following steps.
    Removed Java 6
    Installed Java 7 SDK
    Set JAVE_HOME to new Java 7 location
    Set Path to include new Java location
    On RM start it bombs out with the following error:
    # A fatal error has been detected by the Java Runtime Environment:
    #  SIGSEGV (0xb) at pc=0x00007fff8d7f4221, pid=18806, tid=52231
    # JRE version: Java(TM) SE Runtime Environment (7.0_45-b18) (build 1.7.0_45-b18)
    # Java VM: Java HotSpot(TM) 64-Bit Server VM (24.45-b08 mixed mode bsd-amd64 compressed oops)
    # Problematic frame:
    # C  [libGLImage.dylib+0x24221]  storeColor+0x5d1
    # Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
    # An error report file with more information is saved as:
    # /Users/paulalford/Desktop/rapidminer/hs_err_pid18806.log
    # If you would like to submit a bug report, please visit:
    http://bugreport.sun.com/bugreport/crash.jsp
    # The crash happened outside the Java Virtual Machine in native code.
    # See problematic frame for where to report the bug.
    ./scripts/RapidMinerGUI: line 195: 18806 Abort trap: 6          $JAVA $ADDITIONAL_OPTIONS -Xmx${MAX_JAVA_MEMORY}m -XX:MaxPermSize=128m -cp ${CLASSPATH} -Drapidminer.home=${RAPIDMINER_HOME} -Drapidminer.operators.additional=${RAPIDMINER_OPERATORS_ADDITIONAL} ${RAPIDMINER_JDBC_DRIVER_PARAMETER} com.rapid_i.Launcher "$@"
    Would be grateful if someone could point me in the right direction.
    Thanks in advance.
    User: "jfork"
    This same problem is happening to me.  I am running Java 7 SDK.  I got RM to run on my Macbook air running Mountain Lion, but cannot get it to import CSV or excel.  When I try to use the Import data command, nothing happens....
    On my iMac running Mavericks, I cannot even get RM to open, it shows the loading screen, then the GUI crashes with a message similar to what Paul Alford reports.  I don't know enough about the code to be able to understand what it's doing wrong or how to fix it.
    Hi,
    just to be clear: You are trying to press the arrow next to the button, and nothing happens? (Yes, I know this is not optimal and it will be changed in the future.)
    Regards,
    Marco
    User: "earmijo"
    I had exactly the same problem. I'm running Mavericks and Rapidminer Version 5.3.13.
    I had Java 7 installed but Mac was not using it (when i ran "java -version" I got the version 1.6).
    I followed the steps described in the page:
    http://apple.stackexchange.com/questions/58116/enabling-java-7-on-mountain-lion
    and everything works as expected after that.
    User: "tmanasa"
    Having the same issues on Mavericks with RM 5.3.015. If Java 7 is installed, RM crashes out at GUI start with EXC_BAD_ACCESS (see below).
    If I remove Java 7 and use Apple Java 6, then RM starts but neither CSV, Excel, nor XML import work.
    Following the steps linked by earmijo didn't fix the issues for me.
    Process:        java [25570]
    Path:            /Library/Internet Plug-ins/JavaAppletPlugin.plugin/Contents/Home/bin/java
    Identifier:      net.java.openjdk.cmd
    Version:        1.0 (1.0)
    Code Type:      X86-64 (Native)
    Parent Process:  Jar Launcher [25568]
    Responsible:    Jar Launcher [25568]
    User ID:        504
    Date/Time:      2013-11-06 20:47:55.362 -0600
    OS Version:      Mac OS X 10.9 (13A603)
    Report Version:  11
    Anonymous UUID:  F61A03F4-5353-DF22-5E4D-AE96814852A5
    Sleep/Wake UUID: FF8CA141-1196-4FCF-8599-A5ED31115931
    Crashed Thread:  29  Java: Java2D Queue Flusher  Dispatch queue: com.apple.root.default-priority
    Exception Type:  EXC_BAD_ACCESS (SIGABRT)
    Exception Codes: KERN_INVALID_ADDRESS at 0x000000012376e000
    User: "tmanasa"
    Bump. Anyone find a way around this?
