"Set Role Operator as document Name [Solved]"
Hi to all,
I used the rapidMiner for clustering purpose, i used K-mean.
My question is how can i know the documents which cluster inside cluster one and which cluster in cluster 2 and so on . Because i need to
calculate the quality of data clusters (using the F-meausre and Entropy).
FYI. my collection of documents around 1000 textual document . These documents named from A1 to A1000. How can i know the document which clustered in each cluster?
Is the any example of how can i used the SET ROLE OPERATOR to set the document name as column after cluster process?
my regards
Wael.
my regards
Wael.
1 - 11 of
111
Many thanks for you Marius :
My steps as following
1) Process documents from Files and inside it Tokenize
2) Set Role Operator
3) Clustering operator (Kmean).
FYI: the set Role operator before the clustering and after the Process Document from files
Wael
<?xml version="1.0" encoding="UTF-8" standalone="no"?>my regards
<process version="5.2.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
<process expanded="true" height="296" width="503">
<operator activated="true" class="text:process_document_from_file" compatibility="5.3.000" expanded="true" height="76" name="Process Documents from Files" width="90" x="45" y="210">
<list key="text_directories">
<parameter key="mydata" value="D:\Classic_subset\ready"/>
</list>
<process expanded="true" height="586" width="559">
<operator activated="true" class="text:tokenize" compatibility="5.3.000" expanded="true" height="60" name="Tokenize" width="90" x="234" y="30"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_port="document 1"/>
<portSpacing port="source_document" spacing="0"/>
<portSpacing port="sink_document 1" spacing="0"/>
<portSpacing port="sink_document 2" spacing="0"/>
</process>
</operator>
<operator activated="true" class="set_role" compatibility="5.2.008" expanded="true" height="76" name="Set Role" width="90" x="112" y="75">
<list key="set_additional_roles">
<parameter key="metadata_file" value="id"/>
</list>
</operator>
<operator activated="true" class="k_means" compatibility="5.2.008" expanded="true" height="76" name="Clustering" width="90" x="246" y="30"/>
<connect from_op="Process Documents from Files" from_port="example set" to_op="Set Role" to_port="example set input"/>
<connect from_op="Process Documents from Files" from_port="word list" to_port="result 1"/>
<connect from_op="Set Role" from_port="example set output" to_op="Clustering" to_port="example set"/>
<connect from_op="Clustering" from_port="cluster model" to_port="result 2"/>
<portSpacing port="sink_result 3" spacing="0"/>
</process>
</operator>
</process>
Wael
Many thanks for yoy Marius,
Also same problem the out put without the file name
<context>
<input/>
<output/>
<macros/>
</context>
<process expanded="true" height="386" width="681">
<operator activated="true" class="text:process_document_from_file" compatibility="5.3.001" expanded="true" height="76" name="Process Documents from Files" width="90" x="45" y="255">
<parameter key="ssssss" value="F:\dataset"/>
</list>
<process expanded="true" height="519" width="806">
<operator activated="true" class="text:tokenize" compatibility="5.3.001" expanded="true" height="60" name="Tokenize" width="90" x="358" y="30"/>
</process>
</operator>
<operator activated="true" class="k_means" compatibility="5.2.008" expanded="true" height="76" name="Clustering" width="90" x="112" y="75"/>
<operator activated="true" class="set_role" compatibility="5.2.008" expanded="true" height="76" name="Set Role" width="90" x="246" y="30">
<parameter key="name" value="metadata_file"/>
<parameter key="target_role" value="id"/>
</list>
</operator>
<connect from_op="Process Documents from Files" from_port="example set" to_op="Clustering" to_port="example set"/>
<connect from_op="Clustering" from_port="clustered set" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_port="result 2"/>
<portSpacing port="sink_result 3" spacing="90"/>
</process>
</operator>
</process>
I do like the follwing:
Or
2) Clustering operator (Kmean).
3) Set Role Operator .
Please have a look to this :
Or
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="text:process_document_from_file" compatibility="5.3.001" expanded="true" height="76" name="Process Documents from Files" width="90" x="45" y="210">
</list>
</process>
</operator>
<operator activated="true" class="set_role" compatibility="5.2.008" expanded="true" height="76" name="Set Role" width="90" x="179" y="75">
</list>
</operator>
<operator activated="true" class="k_means" compatibility="5.2.008" expanded="true" height="76" name="Clustering" width="90" x="313" y="75"/>
<connect from_op="Clustering" from_port="clustered set" to_port="result 3"/>
<portSpacing port="sink_result 4" spacing="0"/>
</process>
</operator>
</process>
Hi marius,
Yes, i already upgrade my version now.
I want to show the document name in the cluster .
for example using the K-mean, i produce 5 clusters based , i want to know which document inside which cluster.
for example :
I have document a , b, c , d and so on , if the document b and c in one cluster just show me the name of documents as attribute.
if you ask me Why i need that ?
i need to calculate the f-measure based on my data set.
my regards
Wael.
for example :
my regards
Wael.
Many thanks for you Mr.Marius for you help .... Yes already done . Thanks alot ..
have alook to this
have alook to this
<process version="5.3.013">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process">
<process expanded="true">
<parameter key="oo" value="D:\Classic_subset\test"/>
</list>
</process>
</operator>
<operator activated="true" class="set_role" compatibility="5.3.013" expanded="true" height="76" name="Set Role" width="90" x="112" y="75">
<parameter key="attribute_name" value="metadata_file"/>
<list key="set_additional_roles"/>
</operator>
<operator activated="true" class="k_means" compatibility="5.3.013" expanded="true" height="76" name="Clustering" width="90" x="246" y="30">
<parameter key="max_runs" value="1"/>
<parameter key="max_optimization_steps" value="1"/>
</operator>
<connect from_op="Process Documents from Files" from_port="word list" to_port="result 2"/>
<connect from_op="Clustering" from_port="cluster model" to_port="result 1"/>
</process>
</operator>
</process>
use the set Role operator before the clustering operator to define the column that contains the document names as id.
Best regards,
Marius
