1 - 3 of
31
Hey Nils,
Thanks.
So basically what your saying is.
Create numeric attributes.
(Numeric attributes write 0.0 and 1.0 by the way).
Or should I use "1" and "0" in string value?
To create a nominal attribute?
I guess that would really write out what I was asking for.
Best regards,
Wessel
Thanks.
Best regards,
Wessel
you can use a Generate Attributes to create an attribute which contains 1 in case of true and 0 in case of false. Then remove your old attribute
and rename the created one to your desired name.
Best,
Nils
