1 - 2 of
21
Thank you!
And what if I have 0.11 and 0.123 numbers?
If I save the result with Write CSV then I will have the correct number of digits, so there will be no extra zeros. But if I use the Read CSV output at Generate Report, then my report will contain 3 digit numbers: 0.110; 0.120. If I set 'rapidminer.general.fractiondigits.numbers' from 3 to 2 then my 0.123 number will change into 0.12 and the report will conatin this, not the original
that is still the original number
However you can instruct RapidMiner to only use 2 fraction digits, to do so click Tools -> Preferences -> General and edit the setting which says 'rapidminer.general.fractiondigits.numbers' from 3 to 2.
Regards,
Marco
