🎉Community Raffle - Win $25
Join and Win
Using Read Documents from Files for Hundreds of Single-Document Classes
User: "Emi"
New Altair Community Member
Updated by Jocelyn
Hi,
I have about a thousand documents in a single folder and would like to use the "Read Documents from Files" operator to process them. I realize I need to have a folder for each document if I would like to indicate each document as a class. I am wondering if there are other operators or a smart way of achieving the same thing as it seems impractical to manually create a folder for each document and also manually indicate each folder as a class in "text directories" parameter of the "Read Documents from Files" operator.
Thank you.
1 - 1 of 11
    User: "Andrew2"
    Hello
    The file name is provided as meta data so you can parse this using the generate attributes operator.
    Regards
    Andrew
