🎉Community Raffle - Win $25
Join and Win
Open circuit test transformer on flux2D
User: "Flower_974"
New Altair Community Member
Updated by Flower_974
Hello,
I made the geometry for a single-phase transformer on Flux2D. I know the values of the current and the voltage that I am supposed to have  in the stator and the rotor during an open circuit test, and also the phase difference and the transformation ratio. And I would like to see if I get the same results with the software. The stator is on the left of the picture. On the right, there is the rotor with an infinite resistance. Since I know the transformation ratio, I know the value and the phase of the voltage to put in the software. But I don't know if it's the way to do on Flux2D. When you create the circuit, where do you indicate the mutual inductance between the rotor and stator ?
Thank you in advance!
1 - 1 of 11
    User: "asoualmi"
    Altair Employee
    Updated by asoualmi
    Hi,
    In Flux 3D supervisor example, there is an example about the transformers and different tests that you need to do. I think you can check this example (no load test) to see how we do it in Flux.
    Best regards.
