[SOLVED] fliter example process can not invoke condition
Hi Dears
when i tried to set parameter string to "date_added >2012-05-24 13:20:29" after i chose " condition class" to "attribute_value_filter
the message box with error said :
Reason :come.rapidminer.example.set.AttributeVlueFilter: cannot invoke condition (could not parse value '2012-05-24 13:20:39' with date pattern yy-mm-dd HH:mm:ss Z)
i tried to surround the date with quote and double quote but same message appeared
i really want to filter examples refer to date and i hope to get suitable format to set the parameter correctly
note1 :"date_added" is the name of the column from table on database
note 2: i used rapidminer 5.3.008 on my mac
<operator activated="true" class="filter_examples" compatibility="5.3.008" expanded="true" height="76" name="Filter Examples" width="90" x="179" y="75">
<parameter key="condition_class" value="attribute_value_filter"/>
<parameter key="parameter_string" value="date_added >2012-05-24 13:20:39"/>
</operator>
1 - 3 of
31
Best regards,
Marius
