Altair RISE
Nominate Yourself Now!
[SOLVED] Memory consumption in RapidMiner
User: "Mandar"
New Altair Community Member
Updated by Jocelyn
Hello Everyone,
I have been using RapidMiner to build models having 500K records and each record having 1000 attributes. I use the Read Database operator and then perform variable reduction using the 'Remove Useless Attributes' operator. I have to perform additional operations to determine the importance of the attributes with respect to the target but I have been facing memory constraints.
I have observed that after each operation RM reserves more memory and then it ends up giving an error which asks me to allocate more space to the software. I have a powerful machine with 16GB RAM and I have allocated 13GB to RM but since it does not free the memory and I keep on facing the same issue. I have tried using the 'Free Memory' operator but it frees up memory of unused objects and it does not end up freeing memory in my case. Is there a way to tell RM explicitly to free memory after an operation has been completed. I would appreciate any help in this matter.
Thanks,
Mandar
