🎉Community Raffle - Win $25
Join and Win
HyperStudy MotionView Solver Pop-up/progress
User: "Andreas_21886"
Altair Community Member
Updated by Andreas_21886
Hi all,
When you carry out a run in MotionView with the offline setting you get a little pop-up window which tells you the solvers progress and any interupts. I was wondering if there was a way to get this window to show when you run a batch of MotionView runs in Hyperstudy instead of/with the static MotionView window that normally pops up when you begin solving?
Best,
Andreas
1 - 1 of 11
    User: "Orestis_YB"
    Altair Employee
    Updated by Orestis_YB
    Hello Andrea,
    In Define Model you could try adding -screen in solver input arguments as shown below.
    I noticed that I had to close the log for the next simulation to start which means that it may not be ideal if you want to leave it simulating.
    Logs are also available within each run directory as text files and the contain the exact same information you see in MotionSolve window.
    Hope this helps!
    Best regards,
    Orestes
