Altair RISE
Nominate Yourself Now!
Script: name for bolts
User: "Alex.01"
Altair Community Member
Updated by Alex.01
Hi all,
I want to do an script which makes this:
I have a model with a lot of bolts which are formed for 4 or 5 bar2 elements. I want to do an script which groupes each bolt (with its bar2 elements) and generates a tag or name for it (i.e. Bolt 1, Bolt 1001). The input would be 1 bar2 element, and I think I could do it by using *findmark command but I don't know how to carry on.
Do you have any ideas to help me ?
Thanks in advance.
Regards,
Alex
1 - 3 of 31
    User: "tinh"
    Updated by tinh
    Can you take a photo to shows what you had, and another that shows what you want?
    I can't understand your description
    User: "Alex.01"
    OP
    Updated by Alex.01
    Hi tinh, thanks for your answer but finally I could do the script.
    Anyway, what I had was this (bolt made with several 1d elements):
    And what I wanted was this (a tag with a ID for the bolt, i.e.5003) :
    But as I said before I could develop de script.
    You can delete this topic if you want considering it doesn't contribute to the forum.
    Many thanks.
    User: "tinh"
    Updated by tinh
    Hi, It's good
    so you will input 1 bar elem, and then use *findmark to find attached bar elems to group them?
    you also can use *createmark with option 'by attached'.
