[SOLVED] Transform content of one column into n columns
User: "marcopo"
New Altair Community Member
Updated by Jocelyn
Hello Community,
the cells of one column( Abbreviations) in my repository contains multiple entries. The column is string and contains multiple abbreviations for example one cell contains (BSU MSE DFG ETS SGJ TZS). I woud love to create for every abbreviation an own column and if the row contains the abbreviation the boolean attribute will be true in the cell. Exist a possible operator?
Row    Abbreviations                            BSU         MSE       DFG     ETS     SGJ     TZS  XYZ  TSA
1         (BSU MSE DFG ETS SGJ TZS)  true           true       true     true     true     true   false   false
2         (BSU MSE DFG ETS SGJ TZS)   true           true       true     true     true     true   false   false
3         (BSU MSE DFG ETS SGJ XYZ)  true           true       true     true     true     false   true   false
4         (BSU MSE DFG ETS SGJ TSA) ) true           true       true     true     true     false  false  true
Is it possible in Rapidminer?
Thanks in advance
1 - 2 of 21
    User: "Andrew2"
    Hello
    Yes it is - here's an example that I think does what you want.
    <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    <process version="5.3.008">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process">
        <process expanded="true">
          <operator activated="true" class="generate_data_user_specification" compatibility="5.3.008" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="45" y="75">
            <list key="attribute_values">
              <parameter key="abbreviations" value="&quot;AA BB DD&quot;"/>
            </list>
            <list key="set_additional_roles"/>
          </operator>
          <operator activated="true" class="generate_data_user_specification" compatibility="5.3.008" expanded="true" height="60" name="Generate Data by User Specification (3)" width="90" x="45" y="165">
              <parameter key="abbreviations" value="&quot;EE BB DD&quot;"/>
            </list>
          </operator>
          <operator activated="true" class="generate_data_user_specification" compatibility="5.3.008" expanded="true" height="60" name="Generate Data by User Specification (2)" width="90" x="45" y="255">
              <parameter key="abbreviations" value="&quot;AA BB CC EE&quot;"/>
            </list>
          </operator>
          <operator activated="true" class="append" compatibility="5.3.008" expanded="true" height="112" name="Append" width="90" x="246" y="75"/>
          <operator activated="true" class="split" compatibility="5.3.008" expanded="true" height="76" name="Split" width="90" x="380" y="75">
            <parameter key="split_pattern" value=" "/>
            <parameter key="split_mode" value="unordered_split"/>
          </operator>
          <operator activated="true" class="rename_by_replacing" compatibility="5.3.008" expanded="true" height="76" name="Rename by Replacing" width="90" x="514" y="75">
            <parameter key="replace_what" value=".*_(.*)"/>
            <parameter key="replace_by" value="$1"/>
          </operator>
          <connect from_op="Generate Data by User Specification" from_port="output" to_op="Append" to_port="example set 1"/>
          <connect from_op="Generate Data by User Specification (3)" from_port="output" to_op="Append" to_port="example set 2"/>
          <connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Append" to_port="example set 3"/>
          <connect from_op="Append" from_port="merged set" to_op="Split" to_port="example set input"/>
          <connect from_op="Split" from_port="example set output" to_op="Rename by Replacing" to_port="example set input"/>
          <connect from_op="Rename by Replacing" from_port="example set output" to_port="result 1"/>
        </process>
      </operator>
    </process>
    regards
    Andrew
    User: "marcopo"
    OP
    Hi,
    thank you very much, Its working ;-)
