🎉Community Raffle - Win $25
Join and Win
The results of simulation look different from the process
User: "Jia-syuan Wu"
Altair Community Member
Updated by Jia-syuan Wu
Hi here, I am using EDEM 2022.3 to simulate the process of the particles falling from the factory due to gravity. I am confused by the simulation result it is quite different from the process. The screenshot on the left-hand side is the process, which looks good. But once the simulation is finished, it looks like the one on the right-hand side, which is weird. I try to replay the process in the analyst section, but it only shows the result like the later one. I wonder whether I mistake something and how to fix this, but it seems like there is no similar discussion in the community (or it is, but I am too stupid to find it:( )
Thanks in advance to everyone who offers to assist :)
1 - 2 of 21
    User: "Eric_Veikle"
    Altair Employee
    Accepted Answer
    Updated by Eric_Veikle
    Hello Jia-syuan,
    I think the issue you are observing here is related to the graphics card.  Try to got to Tools > Options > and enable " Render all using legacy display".  If that does the trick and the particles are showing up in their expected size I would then update your graphics drivers and see if that will allow you to go back to the rendering without legacy display.
    Kind Regards,
    Eric
    OP
    Hello Jia-syuan,
    Kind Regards,
    Eric
    Hello Eric!
    Thank you for your reply! It's exactly what I needed, and my problem is fixed. Thank you very much!
    Best Regards,
    Jia-syuan
