🎉Community Raffle - Win $25
Join and Win
[SOLVED] W-Apriori not appear in Perspective Results
stoggioniUser: "stoggioni"
New Altair Community Member
Updated by Jocelyn
Hello,
I have a problem. The result of the algorithm W-Apriori not appear in the Results Perspective RapidMiner. I saw that the algorithm generates the rules, but I could only see by hovering over port res. And tested it with other algorithms from the Weka and also do not appear.
Anyone have any suggestions of what is happening?
Thank you!
1 - 2 of 21
    Hi,
    that's unfortunately a bug that snuck in :(
    Some operators are missing their result display at the moment. They still produce results, but do not show them in the Results perspective. This has already been fixed internally and will be fixed for everyone in the next release.
    I'm afraid your options are only to a) wait for the next release (for which I do not have a date), or b) to download the current development RapidMiner sources here and build RapidMiner yourself.
    Regards,
    Marco
    hi,
    thanks for replying ...  :D
    I think one solution is to export the results as a file of type text
    Thank you!
