[SOLVED] Applying Association Rule after generating Association Rule
Hi team
Please help me in using process "Applying Association Rules" to a dataset.
I have a data with CustomerID, ProductName, Revenue
I created a set of association rule based on the above metrics (revenue used as weight)
Now I want to create a data set which has one more column(s) showing Recommended product based on association rules created above.
I tried using process"Applying Association Rules", but it asks for some binary variable, actually it says revenue should be binary!!!
Please help and suggest solution to this
Thanks
Deepak
Thanks
Deepak
1 - 5 of
51
Hi Marius,
Thanks for the reply, It's working now
Now I am struggling to interpret the results of the output after applying Association rules, the results are as below
List of ID's and columns representing existing product names with values as true/ false (if product is subscribed/not subscribed)
and few new columns as "Confidence(prod1)", "Confidence(prod2)" etc. having values 1/0.
I assume that these column may be recommended products, but a close inspection shows some products in recommended list are already subscribed
Any thoughts on this
Regards
Deepak
Regards
Deepak
Indeed the 0/1 indicates recommendations. In fact some of the products can already be subscribed. The reasoning is the following. Suppose the following rule:
[A,C] => B
And the user has the products [A, B, C]. Then the rule matches, and B is suggested.
I will add an internal feature request to check for these duplicates, though.
Best regards,
Marius
most probably you have applied FP-Growth before Create Association Rules. You should pass the same data set you passed into FP-Growth into Create Association Rules.
If my assumption is not true, please provide your processes and a detailed description of your data.
Best regards,
Marius
