RM pinning to win7 taskbar
I don't know whether others have the same problem, but for me RM does not behave the way win7 likes applications to behave on the taskbar.
Usually, an application can be "pinned" to the taskbar, serving as a shortcut when the application is not running. It does not seem possible to pin RM to the taskbar (i.e. the context menu does not have that option). Dragging an RM shortcut onto the taskbar works, but the resulting shortcut is a completely separate button on the taskbar, so that there are two (same-looking) RM buttons when RM is actually running.
1 - 4 of
41
Good point. I have created an internal feature request.
Well, apparently even Netbeans was struggling with this at one stage, as well as many others, but it doesn't seem impossible.
As one poster in the Netbeans bug report forum put it, perhaps a little too strongly:
...for people with Windows 7 64-bit and it makes Netbeans look very unprofessional when it is the one application that fails to integrate with the taskbar.
