🎉Community Raffle - Win $25
Join and Win
[SOLVED] ReadCSV escape characters disappear even when quotes disabled
User: "tennenrishin"
New Altair Community Member
Updated by Jocelyn
If the ReadCSV operator's "use quotes" parameter is off, the "escape character for quotes" parameter is hidden. This suggests that the "escape character for quotes" is only relevant when "use quotes" is on.
However, even with "use quotes" off, my ReadCSV operator seems to be removing '\' characters from the read content, unless I set "escape character for quotes" to some other character.
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.3.005">
 <context>
   <input/>
   <output/>
   <macros/>
 </context>
 <operator activated="true" class="process" compatibility="5.3.005" expanded="true" name="Process">
   <process expanded="true">
     <operator activated="true" class="read_csv" compatibility="5.3.005" expanded="true" height="60" name="Read CSV" width="90" x="112" y="75">
       <parameter key="csv_file" value="C:\Users\isak\Desktop\a.txt"/>
       <parameter key="use_quotes" value="false"/>
       <parameter key="parse_numbers" value="false"/>
       <list key="annotations"/>
       <list key="data_set_meta_data_information">
         <parameter key="0" value="content.true.nominal.attribute"/>
       </list>
     </operator>
     <connect from_op="Read CSV" from_port="output" to_port="result 1"/>
   </process>
 </operator>
</process>
[quote=a.txt]1
.*,CLS\(.*[/quote]
1 - 2 of 21
    User: "MariusHelf"
    Thanks for reporting. I have created an internal bug report.
    Best regards,
    Marius
    User: "Skirzynski"
    We have renamed the parameter ("escape_character") and removed the parameter dependency (i.e. the parameter is always displayed) to make clear that this character will not only be used for quotes. The next release will contain these changes.
