🎉Community Raffle - Win $25
Join and Win
"[SOLVED] Count ignoring missings in Aggregate operator"
User: "tennenrishin"
New Altair Community Member
Updated by Jocelyn
The selectable aggregation functions for the Aggregate operator include:
"count (ignoring missings)", as well as
"count (including missings)".
The operator also has another boolean parameter called "ignore missings".
Do these mean different things, and if not, what happens when the two parameters are set to contradictory values?
1 - 2 of 21
    User: "MariusHelf"
    Hi,
    actually, if activate the option "ignore_missings", none of the function actually counts the missings, not even count(including missings).
    If you deactivate the parameter, the functions do not seem to work  >:( I have just filed an internal bug report about this.
    Best regards,
    Marius
    User: "MariusHelf"
    Just got a message from the developers: the problem has already been fixed and will be part of the next release :)
