🎉Community Raffle - Win $25
Join and Win
Transient Analysis and Bolt Preload
User: "cx g"
Altair Community Member
Updated by cx g
Hi, I'm running into a problem while doing a transient analysis. I want to do a transient analysis with bolt preload, I set up two loadsteps, bolt preload and transient analysis, but I can't link them together.
I tried STATSUB (PRELOAD) but it doesn't work.
Please refer to attachment.
Please help me in this regard ...
This is very urgent and important ...
1 - 3 of 31
    User: "RobinsonFerrari"
    Altair Employee
    Accepted Answer
    Updated by RobinsonFerrari
    Hi. Please see the deck file attached running step 1 as a pretension load and step 2 applying the load using the same tabled1 you have created. Use TS time = SUB for TLOAD or adjust the curve in TABLED1 from 1 to 4s.
    Use NLSTAT for pretension load step.
    For the non-linear transient use Force instead of DAREA, use CNTNLSUB to continue from load step 1 and add pretension load step to statsub(pretens) field to fix the pretension load applied at step 1.
    Thank you,
    Altair Employee
    I hope it helps and please don't forget to highlight as correct answer :)
    User: "cx g"
    OP
    Updated by cx g
    Sorry I forgot. The correct answer has now been marked.
