RApidAnalytics update
User: "StaryVena"
New Altair Community Member
Updated by Jocelyn
Hello,
how can I update RapidAnalytics's RapidMiner (that rapidminer.jar included in {RapidAnalyticsHome}/server/default/tmp/vfs/automount33e9b20ac4cff840/RapidAnalytics-CE-1.2.008.ear-9f8fc265172dc78a/contents/lib/rapidminer.jar). I tried to ovewrite rapidminer. jar in {RapidAnalyticsHome}/server/default/deploy/ROOT.war/webstart/rapidminer.jar, but it didn't affect rapidminer.jar file in tmp folder. Or is it even possible to upgrade RA this way?
I need it because of http://rapid-i.com/rapidforum/index.php?topic=6002.0 update. The newest RA installation file what I found is older than this bug fix. So is there any way to get newer version?
Thank you for answers.
Václav
1 - 5 of 51
    User: "Nils_Woehler"
    Hi Václav,
    we are going to release a new version of RA today or next week. This should fix your problem.
    Best,
    Nils
    User: "StaryVena"
    OP
    Hi Nils,
    I have updated RA to new version, but there is still problem:
    /home/vaclav/loopTest
    com.rapidminer.operator.UserError: No data was delivered at port Loop Collection.collection (connected).
    log:
    Mar 25, 2013 2:02:57 PM <unknown> <unknown>
    INFO: Process context is: Macros: [_ra_user : vaclav, _ra_jobID : 5]; Input: []; Output: []
    INFO: No filename given for result file, using stdout for logging results!
    INFO: Process //_LOCAL/home/vaclav/loopTest starts
    SEVERE: Process failed: com.rapidminer.operator.UserError: No data was delivered at port Loop Collection.collection (connected).
    at com.rapidminer.operator.ports.impl.AbstractPort.getData(AbstractPort.java:99)
    at com.rapidminer.operator.collections.CollectionIterationOperator.doWork(CollectionIterationOperator.java:89)
    at com.rapidminer.operator.Operator.execute(Operator.java:855)
    at com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:51)
    at com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:711)
    at com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:379)
    at com.rapidminer.Process.run(Process.java:949)
    at com.rapidminer.Process.run(Process.java:873)
    at com.rapidminer.Process.run(Process.java:832)
    at com.rapidminer.Process.run(Process.java:827)
    at de.rapidanalytics.execution.AbstractProcessExecutor.runProcessNow(Unknown Source)
    at de.rapidanalytics.execution.SimpleProcessExecutor.execute(Unknown Source)
    at de.rapidanalytics.execution.ProcessExecutionDispatcher.dispatch(Unknown Source)
    at de.rapidanalytics.ejb.ProcessJobEJBImpl.executeJob(Unknown Source)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
    at java.lang.reflect.Method.invoke(Method.java:616)
    at org.jboss.aop.joinpoint.MethodInvocation.invokeTarget(MethodInvocation.java:122)
    at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:111)
    at org.jboss.ejb3.interceptors.container.ContainerMethodInvocationWrapper.invokeNext(ContainerMethodInvocationWrapper.java:72)
    at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.invoke(InterceptorSequencer.java:76)
    at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.aroundInvoke(InterceptorSequencer.java:62)
    at sun.reflect.GeneratedMethodAccessor408.invoke(Unknown Source)
    at org.jboss.aop.advice.PerJoinpointAdvice.invoke(PerJoinpointAdvice.java:174)
    at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
    at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.fillMethod(InvocationContextInterceptor.java:74)
    at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_fillMethod_1180675534.invoke(InvocationContextInterceptor_z_fillMethod_1180675534.java)
    at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.setup(InvocationContextInterceptor.java:90)
    at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_setup_1180675534.invoke(InvocationContextInterceptor_z_setup_1180675534.java)
    at org.jboss.ejb3.async.impl.interceptor.AsynchronousServerInterceptor.invoke(AsynchronousServerInterceptor.java:128)
    at org.jboss.ejb3.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionInterceptor.java:62)
    at org.jboss.ejb3.entity.TransactionScopedEntityManagerInterceptor.invoke(TransactionScopedEntityManagerInterceptor.java:56)
    at org.jboss.ejb3.AllowedOperationsInterceptor.invoke(AllowedOperationsInterceptor.java:47)
    at org.jboss.ejb3.tx.StatelessBMTInterceptor.handleInvocation(StatelessBMTInterceptor.java:106)
    at org.jboss.ejb3.tx.BMTInterceptor.invoke(BMTInterceptor.java:55)
    at org.jboss.ejb3.stateless.StatelessInstanceInterceptor.invoke(StatelessInstanceInterceptor.java:68)
    at org.jboss.ejb3.core.context.SessionInvocationContextAdapter.proceed(SessionInvocationContextAdapter.java:95)
    at org.jboss.ejb3.tx2.impl.CMTTxInterceptor.invokeInOurTx(CMTTxInterceptor.java:247)
    at org.jboss.ejb3.tx2.impl.CMTTxInterceptor.required(CMTTxInterceptor.java:349)
    at org.jboss.ejb3.tx2.impl.CMTTxInterceptor.invoke(CMTTxInterceptor.java:209)
    at org.jboss.ejb3.tx2.aop.CMTTxInterceptorWrapper.invoke(CMTTxInterceptorWrapper.java:52)
    at org.jboss.aspects.tx.TxPropagationInterceptor.invoke(TxPropagationInterceptor.java:76)
    at org.jboss.ejb3.tx.NullInterceptor.invoke(NullInterceptor.java:42)
    at org.jboss.ejb3.security.Ejb3AuthenticationInterceptorv2.invoke(Ejb3AuthenticationInterceptorv2.java:182)
    at org.jboss.ejb3.ENCPropagationInterceptor.invoke(ENCPropagationInterceptor.java:41)
    at org.jboss.ejb3.BlockContainerShutdownInterceptor.invoke(BlockContainerShutdownInterceptor.java:67)
    at org.jboss.ejb3.core.context.CurrentInvocationContextInterceptor.invoke(CurrentInvocationContextInterceptor.java:47)
    at org.jboss.aspects.currentinvocation.CurrentInvocationInterceptor.invoke(CurrentInvocationInterceptor.java:67)
    at org.jboss.ejb3.interceptor.EJB3TCCLInterceptor.invoke(EJB3TCCLInterceptor.java:86)
    at org.jboss.ejb3.stateless.StatelessContainer.dynamicInvoke(StatelessContainer.java:392)
    at org.jboss.ejb3.remoting.IsLocalInterceptor.invokeLocal(IsLocalInterceptor.java:88)
    at org.jboss.ejb3.remoting.IsLocalInterceptor.invoke(IsLocalInterceptor.java:75)
    at org.jboss.ejb3.async.impl.interceptor.AsynchronousClientInterceptor.invoke(AsynchronousClientInterceptor.java:143)
    at org.jboss.aspects.remoting.PojiProxy.invoke(PojiProxy.java:62)
    at $Proxy217.invoke(Unknown Source)
    at org.jboss.ejb3.proxy.impl.handler.session.SessionProxyInvocationHandlerBase.invoke(SessionProxyInvocationHandlerBase.java:185)
    at $Proxy216.executeJob(Unknown Source)
    at de.rapidanalytics.web.tools.ProcessExecutionJob.execute(ProcessExecutionJob.java:75)
    at org.quartz.core.JobRunShell.run(JobRunShell.java:216)
    at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:549)
    SEVERE: Here:          Process[1] (Process)
              subprocess 'Main Process'
                +- Loop Repository[1] (Loop Repository)
              subprocess 'Nested Process'
          ==>  +- Loop Collection[1] (Loop Collection)
              subprocess 'Iteration'
                      +- Normalize[0] (Normalize)
    Process code:
    <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    <process version="5.3.006">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="5.3.006" expanded="true" name="Process">
        <process expanded="true">
          <operator activated="true" class="loop_repository" compatibility="5.3.006" expanded="true" height="76" name="Loop Repository" width="90" x="179" y="30">
            <parameter key="repository_folder" value="FEtrain/"/>
            <parameter key="entry_type" value="IOObject"/>
              <connect from_port="repository object" to_port="out 1"/>
              <portSpacing port="source_repository object" spacing="0"/>
              <portSpacing port="source_in 1" spacing="0"/>
              <portSpacing port="sink_out 1" spacing="0"/>
              <portSpacing port="sink_out 2" spacing="0"/>
            </process>
          </operator>
          <operator activated="true" class="loop_collection" compatibility="5.3.006" expanded="true" height="76" name="Loop Collection" width="90" x="313" y="30">
              <operator activated="true" class="normalize" compatibility="5.3.006" expanded="true" height="94" name="Normalize" width="90" x="380" y="30"/>
              <connect from_port="single" to_op="Normalize" to_port="example set input"/>
              <connect from_op="Normalize" from_port="example set output" to_port="output 1"/>
              <portSpacing port="source_single" spacing="0"/>
              <portSpacing port="sink_output 1" spacing="0"/>
              <portSpacing port="sink_output 2" spacing="0"/>
            </process>
          </operator>
          <connect from_op="Loop Repository" from_port="out 1" to_op="Loop Collection" to_port="collection"/>
          <connect from_op="Loop Collection" from_port="output 1" to_port="result 1"/>
        </process>
      </operator>
    </process>
    Similar error with appen operator:
    /home/vaclav/test
    com.rapidminer.operator.MissingIOObjectException: The operator needs some input of type com.rapidminer.example.ExampleSet which is not provided.
    Mar 25, 2013 1:37:00 PM <unknown> <unknown>
    INFO: Process context is: Macros: [_ra_user : vaclav, _ra_jobID : 2]; Input: []; Output: []
    INFO: Process //_LOCAL/home/vaclav/test starts
    Mar 25, 2013 1:37:01 PM <unknown> <unknown>
    SEVERE: Process failed: com.rapidminer.operator.MissingIOObjectException: The operator needs some input of type com.rapidminer.example.ExampleSet which is not provided.
    at com.rapidminer.operator.preprocessing.join.ExampleSetMerge.merge(ExampleSetMerge.java:172)
    at com.rapidminer.operator.preprocessing.join.ExampleSetMerge.doWork(ExampleSetMerge.java:166)
                +- Retrieve weights[1] (Retrieve)
                +- Retrieve model[1] (Retrieve)
          ==>  +- Append[1] (Append)
                +- Numerical to Binominal[0] (Numerical to Binominal)
                +- Select by Weights[0] (Select by Weights)
                +- Apply Model[0] (Apply Model)
                +- Performance[0] (Performance)
                +- Store[0] (Store)
    There is still something wrong, but in other part. Hope this post helps fix it.
    Best,
    Václav
    Hi Václav,
    argh, that should have been fixed with 1.3.7! Thanks for reporting.
    I've already identified the issue. Our test somehow tested only the behavior of RM and not RA.
    And this code
    entry.getContainingFolder();
    behaves different on RA and RM... I've created an internal issue for that.
    Best,
    Nils
    User: "StaryVena"
    OP
    Hi Nils,
    so is there something I can do to fix this problem on my RA server? Or should I just wait to another release and when it will be?
    Best wishes,
    Václav
    User: "marton"
    Which Version you are using..If you use latest version it's updated Automatically. I  am using Latest version of RA..Please Type here Your version...
