1 - 7 of
71
Hi,
I could reproduce your negative distances with the Performance (Cluster Distance Performance) operator. But this is not a bug, it is meant to work this way because the distances are multiplied by -1 to allow using them for optimization. If you want to see the positive distances you should select the 'maximize' parameter. But you should not use the resulting performance objects for optimization if you have selected this parameter!
The reason for multiplying by -1: The Performance (Cluster Distance Performance) calculates the average distance within centroids. The smaller the distances are the better the clustering works (in theory). But our optimization operators always try to maximize the performance of an algorithm. This means if you don't multiply be -1, the optimization algorithm would always prefer cluster results with a higher average distance within centroids.
Best,
Nils
Best,
Nils
It is a bug?
Please confirm that I need so I see if I keep using this tool to measure the distance, because it is for an academic and my deadlines expire
Regards
